Question.
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Jun 8, 2016.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I have a 2010 Prius II. Forgive the silly question, but where is the place to charge a cellphone? I see a black cover low on the dashboard, but there doesn't seem to be anything below it.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    Look in the center console - open the top and there should be a charging point at the back close to the bottom.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In the center console, towards the back, is a USB port and AUX in port.
  4. Mendel Leisk
    41,402
    The black cover low on the dash is the cap of a 12 volt outlet. You can plug in a 12 volt to usb adapter, or use a charger cord with dedicated 12 volt plug.
    Or is there literally nothing behind the black cap? Screw up at the factory?
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Its in the center armrest console. I bought a 3" USB cord extension and plugged it in there. That way it is easier to access.
    marlinsmobile likes this.
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    Actually the charging/USB port IS in the console at the lower left of the front inner wall.
  7. Mendel Leisk
    41,402
    Our 2010 only has 12 volt outlets, no usb. OP has 2010, so not sure, maybe depends on country, level?
    southjerseycraig likes this.
  8. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Mendel, my set-up looks like what you describe. I looked at the back of the console, and I see a 12 volt/120 watt outlet. It looks you could plug a car charger right into it. There is an "aux" plug next to it, but it seems not to open. My fiance has a car charger, and I will try plugging hers into the 12 volt/120 watt outlet. Many thanks to all!
  9. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Taking a road trip to Michigan. Using the center console USB port to keep the cell phone charged. Cell mounted on top of center console. Running the Waze GPS app. Have a 2013 model 4 BTW.
  10. ChapmanF
    18,147
  11. BZzap!
    1,607
    878
    image.jpeg A picture is worth a thousand words.
    Bay Stater likes this.
  12. Mendel Leisk
    41,402
    I don't think car charger hookup via interior 12 volt socket would work. The car disconnects outlets when it's off.
  13. BZzap!
    1,607
    878
    So does the USB port. Toyota wants nothing to potentially be able to run the battery dead. Baaaad idea.
  14. macman408
    1,179
    367
    What's the manufacture date of your car (should be printed somewhere in the driver's door jamb)? If I recall correctly, some of the earliest US 2010's didn't have USB, but the later ones did. Mine's from January 2010 and has USB inside the console box.
  15. Mendel Leisk
    41,402
    Our Canadian Aug 2009 build has no usb.
  16. Bay Stater
    534
    771
    Central Mass
    Your picture illustrated an interesting fact. I am missing the console tray! Didn't know it came with one. Mine was bought used last year.
  17. Mendel Leisk
    41,402
    I think they dropped that tray, or made an accessory?
  18. BZzap!
    1,607
    878
    I bought mine aftermarket. Very expensive and totally useless. Live and learn. I believe that tray's design intention was for cell phone of the time. I have a iPhone 6s Plus, so it won't even fit. Other than that I can brag that I have one and you don't.
  19. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Only '10's and '11s, had the tray.
  20. Mendel Leisk
    41,402
    Yeah, we are the chosen. Fits iPhone 5 fine. :p
