  1. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    4th brake light to blow our mind. calling it. #secretstuff.
    edit: woohoo! page 600!
    #11981 Starbrand, Jun 8, 2016
    Dylan Doxey, HelloHybrid and m3pare like this.
  2. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    I've only had the car since Monday, but today I had the windows tinted and ordered a set of WeatherTech mats.
  3. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    @Dylan Doxey finished up some loose ends on the LED retrofit and helped me wire in the new LED luggage lights with quick disconnects. Thanks again Dylan!
  4. sd1810
    sd1810 Active Member
    105
    361
    Socal
    2015 Prius Plug-in
  5. InspectorGadget
    216
    450
    Heber City, Utah
    And today, a new windshield.
    Help a noob.
    @m3pare, or anyone else, what shift knob is that and which LED kit did you install?
    m3pare likes this.
  6. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
  7. m3pare
    679
    1,818
    SoCal (626)
    Shift knob is from Razo, I believe Carmate also supplies the same style. LED luggage lights are from MIT accessories on eBay and the white/blue dashboard LEDs are from Oznium, installed by @Dylan Doxey.
    bonchang, sfv41901, apt5020 and 4 others like this.
  8. andino
    andino Senior Member
    746
    550
    San Jose, CA
    Dylan Doxey likes this.
  9. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
  10. torparts
    torparts Senior Member
    417
    643
    Compton
    Dylan is about to lay a big flat fart! LOL
    car looks great kuya!
    m3pare, Xterra72, sfv41901 and 2 others like this.
  11. Dylan Doxey
    1,389
    3,455
    92
    That's the face I make when I'm saying, "Are you taking my picture again?"
  12. HelloHybrid
    482
    1,483
    You've hit the level of enlightenment with your iron and LEDs that you don't even need to look at what you're soldering (y)
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I knew it was the hatch LEDs when I saw everything opened up but I was thinking u were having the LED color changed by ours truly!
    iPhone ?
    bonchang and m3pare like this.
  14. HelloHybrid
    482
    1,483
    Shoutout to @Starbrand for the heat yellow(?) emblem backings (y)
    I need a car wash.
  15. Starbrand
    493
    1,502
    Westmont, IL
    ah i need to redo it! need to make yellow darker.
    HelloHybrid likes this.
  16. HelloHybrid
    482
    1,483
    it came out alright. i did notice my plates have some orange to it and its not pure yellow
  17. Friend of Bill W.
    109
    164
    Elkhart, IN
    Got my state "HEVY MTL" plate on order. I'm am old headbanger what can I say :)
  18. Xterra72
    Xterra72 Senior Member
    1,406
    1,658
    #11998 Xterra72, Jun 10, 2016
  19. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I have them on my ride. The passenger side make sure you have enough slack. Don't start closing your panel before you test roll down otherwise the cable will get cut
    Xterra72 likes this.
  20. Xterra72
    1,406
    1,658
    @apt5020 , why the passenger side specifically?? what about the driver side?
    So the wires will have to go between the inside of the door panel structure and protective plastic, under the window railing.
    Is there comfortably enough wire lengths to route?
