warm weather prius will not start. Stranded every day for hours till weather cools
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nathaniel McClain, Jun 9, 2016.
  1. Nathaniel McClain
    Nathaniel McClain Junior Member
    40
    Martinsburg, wv
    yeah thats what I'm talking about. Im concerned its not getting power
    52,395
    welcome to prius chat! are you using mini vci to pull the codes?
  3. JC91006
    JC91006 Senior Member
    16,827
    8,600
    You should get an error code if it's not working.....and there weren't any codes indicating the fan wasn't functional
  4. Nathaniel McClain
    40
    Martinsburg, wv
    I'm u sure. I'm using a nicer obd2 at autozone
  5. Nathaniel McClain
    40
    Martinsburg, wv
    I had a lot of gunk in the fan I cleaned out. I have reinstalled it.
    About a two weeks who I had an accident in car liquid nature and used baking soda to clean it. Apparently that was sucked up....
  6. Nathaniel McClain
    40
    Martinsburg, wv
    It would baffle me if that was the cause but would also be awesome if that was it.
  7. JC91006
    16,827
    8,600
    I think you found your problem, overheating can be the only explanation on why it works properly when cool
  8. Nathaniel McClain
    40
    Martinsburg, wv
    Boy I hope so. I'll let you know how it goes. It's happened everyday for last 5 days so I'm sure I'll know tomorrow if it is or not
  9. Patrick Wong
    18,210
    6,514
    So have you actually checked the inverter coolant reservoir to see if fluid turbulence is present when the car is either IG-ON or READY?
    What is "car liquid nature", and where did this spill occur?
  10. Nathaniel McClain
    40
    Martinsburg, wv
    rear passenger floor board. my son spilled a cup of lemonade. I soaked in baking soda to get it up but the powder apparently got sucked up.
  11. Nathaniel McClain
    40
    Martinsburg, wv
  12. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    With the car in the READY state, the battery cooling fan will be running. Put your ear directly against the fan intake next to the passenger side rear seat. You should hear a quiet fan motor and a bit of air flow.
    Also, if you remove the parts in the rear that cover the spare tire and the 12v battery, you should be able to feel a bit of air coming out of the HV battery exhaust vent. It vents near the 12v battery. Follow the lower black plastic tubing to its end near the 12v battery. After the car has been driven, this exhaust should be hot, or at least warmer than ambient.
    Even during the winter, my battery fan runs anytime the car is in READY. I believe it is intended to always run, regardless of temperature.
  13. Nathaniel McClain
    40
    Martinsburg, wv
    Thanks good to know.
    Well yesterday in the heat I finally had a day of no issue!
    But.... Today again after parking and vining back to drive for two hours..... It wouldn't start. I'm losing it over this car. Just very very frustrating. Wish I. Had a way to keep this thing cooler it that's the issue.
  14. Nathaniel McClain
    40
    Martinsburg, wv
    On a note, it's the hottest it's been today since this year. 92
    Just can't keep going like this all year.
  15. JC91006
    16,827
    8,600
    Did you verify if the inverter coolant pump was operational?
  16. Nathaniel McClain
    40
    Martinsburg, wv
    Yes I did. Good to go
    Heard it run
  17. JC91006
    16,827
    8,600
    I can't ever recall hearing this thing, you must have good hearing
  18. Nathaniel McClain
    40
    Martinsburg, wv
    I meant the turbulence
    I heard the fan in the back. Getting thoughts mixed
  19. bisco
    52,395
    are you parking it in the sun?
  20. bisco
    52,395
    how many miles on her?
