Fog Lights for Trim 4
Discussion in 'Gen 4 Prius Accessories and Modifications' started by munna, Jan 29, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    It's $100/pair ...problem is the manufacturer is in China. Need some company to import it here
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    I've purchased several items directly from the manufacturer off of Alibaba. So far, no problems. It's like a Chinese ebay website.
  3. Tideland Prius
    16,547
    Not sure how that contradicts mine. That's exactly why you don't use high beams in foggy conditions (or blowing snow for that matter).
    Actually parking light and foglights (without low beam) works best because if it really is dense fog, you wouldn't be travelling that fast anyway so you wouldn't need low beams (low beams would still reflect and refract light but obviously not as bad as high beams)
  4. plug-it-in
    plug-it-in Active Member
    179
    113
    Kitchener, ON, Canada
    Maybe I misunderstood your note. If so, my apologies.
    Tideland Prius likes this.
  5. Tideland Prius
    16,547
    No worries :)
  6. iammegiam
    iammegiam Member
    34
    33
    Chicago, IL
    I'm stalking this thread as I'm interested in replacing the fugly caps as well but likely don't have the skills to do an install myself. :(
    Merrilea likes this.
  7. plug-it-in
    179
    113
    I have found a potential solution. These LED accessory lights are made by TRUX (LED Lighting | Trux Accessories). I found these at Princess Auto. The price at C$12.99 is very reasonable. The question is will it make a nice fit? My car is two weeks old, not quite ready to take it a part. :(
    Now, if we want to make them work, not just for show, we have to figure out the wiring. I did a quick, cursory look. It is not easy to get behind the blank bezels.
    fog lights1.jpg The elongated units seem to fit over the existing blank plastic panel nicely.
    View attachment 111993 This picture was taken as reference to see the depth of the device.
    Other solutions are welcome.
  8. Mendel Leisk
    41,290
    Sleep on it.
    xliderider and randomwalk101 like this.
  9. randomwalk101
    532
    271
    texas
    Got my hope up for 0.1 second
  10. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Better of taking the vertical DRL approach since those things wont look stock in s triangular shaped hole. Lol. My opinion.
    Or like I mentioned drill holes in the current blanking plates recesses circle areas and fit multiple small LED lights.
    LG-H901 ?
    xliderider and 4GP2ECOBP like this.
  11. cunnink2
    cunnink2 Member
    55
    Greenville, MS
    krmcg likes this.
  12. plug-it-in
    179
    113
    I am still considering these LED lights. I brought one home and laid it over the blank bezel (vertically!) over the three dimples in the black plastic. Not a bad fit, actually it would look OK. But because the bezel is just so slightly curved and the base of the light is flat - of course - I would have to apply some force, or make some "build up" to set it right - hm... not sure. As I said the car is still too new.
  13. iammegiam
    iammegiam Member
    34
    33
    Chicago, IL
    I can't even find anyone to quote me out on an install. What gives? Augh.
  14. cunnink2
    cunnink2 Member
    55
    Greenville, MS
    Could this be a temporary, cosmetic solution until we get fog lights
    #94 cunnink2, Jun 24, 2016
  15. xliderider
    8,140
    3,274
    Honolulu, HI
    A stick on mirror?
    Frederickdawg and cunnink2 like this.
  16. Merrilea
    Merrilea Junior Member
    Pa
    I obviosly did not do my homework. Was lead to believe that the fully loaded 4 had everything but 17" wheels.
    Prius 4, Hypersonic Red, Harvest Beige, AW Floor Liners / Cargo Tray, ATP and PCP. (Long Boat Trip) Did not expect two gray blanks, need to fill that with some lenses.
    Following this thread with hopes for a reasonable solution. All in time, I know...
    BTW - this is our 4th Prius. Wife dirves the 2012 Prius, gave my 2008 to our daughter.
    krmcg and cunnink2 like this.
  17. randomwalk101
    532
    271
    texas
    Ghetto fabulous!!!! Lol.
    cunnink2 likes this.
  18. CHC
    CHC Junior Member
  19. CHC
    CHC Junior Member
    I ordered a set of OEM fog lights from Cool Toyota in Franklin,TN based on a previous post in this thread. About $200.00 each.The parts guy there assumed the version 3 I have was prewired. Not the case, btw. My 3 has ATP and sun roof. My dealership suggested a place, an after market installer they use and for $150.00 they installed the lights. They had on hand a small unobtrusive switch with a blue LED that fits perfectly with the interior for Gen 4. The switch is directly to the right of the hood release button. I returned the $40.00 Toyota toggle switch Cool sold me and the additional $90.00 OEM stalk switch which would have amounted to a lot more work and installation cost. I am located in Western Michigan. I think this is a viable solution for your fog light concerns. The fog lights look fantastic on the Midnight black of my car.
  20. randomwalk101
    532
    271
    texas
    Congrats on the foglights CHC. I'm still waiting for some cheaper aftermarket. I just can't see myself spending $400+ for the pair of fogs. I can do the install myself just but just too cheap to spend the money on the OEM fogs. :)
