Cruise Control Lurch
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SpaceShip1, Jun 14, 2016.
  1. SpaceShip1
    SpaceShip1 New Member
    Santa Barbara, CA
    New to the prius world. The cruise control has been lurching a bit right when I set it. I think it is maybe because I come off the gas right as I set it, and the engine jumps to catch up. It's sort of hard not to do that though. Anyone else experience this? Or should I get the transmission checked out.
  2. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    That's correct. Try holding the accelerator steady a little longer to give the cruise control time to get its act together.
  3. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    I find that to be normal behavior. Hold the accelerator pedal until CC engages at your desired speed.
  4. ChapmanF
    18,111
    'Lurch' is a good description. I've just moved from a Gen 1 to a Gen 3, and the Gen 3 cruise control annoys me slightly.
    The Gen 1 cruise control I could always engage without making any noticeable lurch, it would pick up at exactly the speed I was driving.
    What I've noticed with my Gen 3 is that any time I hit the SET switch, it seems to set a speed something like ½ mph faster than I'm driving at the time, and then it does a little lurch of acceleration to get there. Not only does the lurch annoy me, I also have to remember to hit the switch about ½ mph below the speed I want.
    I'm not sure why it does that—seems like with all the precision speed sensors all over the car, it would be easy to build a cruise control that got that right. I've wondered if somewhere in software it is rounding the set speed, and if I happen to be halfway between two whole numbers on the speedometer, it rounds up....
    -Chap
  5. SpaceShip1
    Santa Barbara, CA
    Yeah mine does that too, unless I give it a little extra gas right before I set it.
    Now what is also weird, I've noticed when the cruise control goes from EV to ECO (the gas engine kicks on), there's a bit of a lurch too sometimes. You would think there would be some anti backlash setup to prevent that lurch right? Does anyone experience a lurch from electric to gas-electric power.
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    Also, normal...
  7. mrbigh
    3,686
    699
    Long Island, NY
    In the previous 4 Prii I owned since 2005, the CC always had a seamless operation.
