Turn by turn directions using Google maps
Discussion in 'Gen 4 Prius Audio and Electronics' started by HamiltonPrius, Jun 23, 2016.
  1. HamiltonPrius
    HamiltonPrius Member
    130
    68
    Parts unknown
    2026 Prius
    Anyone having trouble getting Google maps to voice turn by turn directions using an iPhone 6s over the base head unit?
    If anyone is interested I found a way to do it.
    51,838
    that's pretty sweet. my brother was in the car with me today using google nav w/ traffic on his i-6. what an amazing free product!(y)
  3. booke02
    booke02 Active Member
    391
    415
    Israel
    There is no factory-installed navigation system in this country, so I was planning on using Waze. However, because Waze collects information from other drivers about traffic conditions (which is a good thing) it requires a dongle and SIM for communications. Navigator would definitely be another option that I would be keen to try. So what is the secret
  4. HamiltonPrius
    130
    68
    Parts unknown
    2026 Prius
    I don't know if it is a secret. I don't have nav on my head unit so I wanted to have Google maps voice turn by turn directions using my equipment a Prius 2 and an iPhone 6s.
    I'm no tech guru but this isn't very hard to do, it's accomplished but just turning on a not so obvious setting. If you have my equipment I can tell how to get it to work.
  5. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    Please do.
  6. booke02
    391
    415
    Israel
    Do tell
  7. HamiltonPrius
    130
    68
    Parts unknown
    2026 Prius
    In your iPhone 6s......
    Go to Google Maps
    Top left there are three parallel lines
    Tap the parallel lines and scroll down to settings
    Tap settings
    Go to navigation settings
    Tap nav settings
    Play voice over Bluetooth should already be turned on
    Turn on Play as Bluetooth phone call....that will activate the voice commands
    Get out out of settings and type in a location and then tap the blue arrow to start the program
    Every time a voice command is voiced it will show on the head unit screen as a call coming in
    RCO, Xterra72 and bisco like this.
  8. bisco
    51,838
    that's pretty cool.:cool:
  9. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    Thanks for that...
    That works well with our 2016 Prius v Three and my iPhone 5s. I did notice however the Play as bluetooth phone call setting is not persistent between uses, i.e. I need to enable that settle each time. Maybe it's just my phone running iOS 9.3.2 and Google Maps 4.20.85272...
  10. HamiltonPrius
    130
    68
    Parts unknown
    2026 Prius
    Yes, you have to turn that setting on every time you want to use the app.
    Sooner Al likes this.
  11. Prius_noob18888
    Prius_noob18888 Junior Member
    44
    39
    Singapore
    Works like a charm. Thanks!
  12. MikeDee
    MikeDee Senior Member
    1,576
    596
    San Francisco Bay Area
    Why is it that the default is no sound when you have Bluetooth connected? Major bug/screw up if you ask me. You shouldn't have to fumble with your phone while driving to get the sound to work. Does Apple Maps have this problem?
    #12 MikeDee, Feb 25, 2017
  13. MikeDee
    1,576
    596
    I found that if you set the audio source on the Prius to Bluetooth, it works, but you can't listen to music other than what comes over your phone.
    RCO and Bluegrassman like this.
  14. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    No love for Android (specifically Samsung) users???
    I like to set this turn by turn on my Samsung phone too.
  15. MikeDee
    1,576
    596
    What's the best strategy to hear Google Maps audio with the least amount of fuss? I don't want to have to drill down into settings each time I use it. I don't care if the audio comes from the phone either.
  16. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    LEAST amount of fuss is phone speaker. But selecting Bluetooth as your audio source does not involve drilling down into your audio settings. It's just an audio source, selected like any other source.
    RCO likes this.
  17. MikeDee
    1,576
    596
    If you have to select the 3 lined menu in the upper left, then Settings, then Navigation, then your audio source, I call that drilling down and a royal pain.
    RCO likes this.
  18. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    If you have to do all that, then I may well agree. I was suggesting that you don't.
    One of us may be confused, but selecting Bluetooth audio from your phone has nothing to do with Navigation settings, or Navigation at all so far as the car is concerned.
    As mine is a European version I won't suggest exactly how you do that but this is just an audio source that you need to select just like changing from FM radio to USB audio.
    RCO likes this.
