77+ MPG with Ease
Discussion in 'Gen 4 Prius Main Forum' started by jettlash1000, Jun 23, 2016.
  1. jettlash1000
    jettlash1000 Junior Member
    51
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Thanks - awesome!!
    ETP, jettlash1000 and GaryD1 like this.
  3. jettlash1000
    51
    You're welcome!
    ETP likes this.
  4. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    It was fun seeing your drive to work! Thanks for posting!!
    Now what other new toys are you going to buy and post? Funny, I told my kids, it's "that guy" from PriusChat.com that is responsible for these yummy egg/muffins... and knowing what the temperature and humidity is (inside and out)!
    Thanks... keep em coming!
    ETP, jettlash1000 and alanclarkeau like this.
  5. jettlash1000
    51
    This literally made me laugh out loud. My wife just gave me an odd look :)
    Just posted another prius video. Any suggestions for new toys? My wife will not be thrilled...
    #5 jettlash1000, Jun 25, 2016
    ETP and PriUncut like this.
  6. Tideland Prius
    16,588
    From 70mph, you should be able to get all 8 bars if you brake for a longer period than you have. For example, you can glide down that slight incline before your exit (right around in the video when you were trying to get the engine off. Once you have it off, I noticed you were coasting. Try to glide instead, use the incline to maintain speed and then try to fill the CHG bar so that you don't have to use your brake pads for that right turn. If there's no traffic behind, maybe even start braking several 10s of feet before you enter the off-ramp.
    Also, great tip near the end about learning your commute and figuring how to end your trip to benefit the start of the trip.
    One thing I noted, because you have the NiMH battery and most owners will end up with the Li-Ion battery, is that you were driving with the HSI bar in the Eco Hybrid area (within the 1st half of the Hybrid System Indictaor) and using the NiMH battery. This is a big change for the Gen 4 with the improved efficiencies of the electric motor and inverter and so forth (all that 20% improvement in energy loss that Toyota talks about). I wouldn't do that in the my Gen 2 or 3 because I wouldn't be able to sustain that entire length of your drive that you did in EV mode because the battery would drain and the engine would come on to recharge. The fact you were able to do that section in EV mode and still end up at work with 3 bars remaining is amazing!
    jettlash1000, ETP and PriUncut like this.
  7. PriUncut
    268
    266
    Southern California
    Four Touring
    Yeah, I saw that one too... on YouTube right after it was posted. I miss-read a portion of the title... and thought it said "2016 Prius Stuck On The Highway" :LOL:.
    You've got all toys I want! I really wish I could get an Echo... just for the home automation aspect.
    Next I'm getting a new camera... I'm sick of cell phone cameras.
    jettlash1000 and ETP like this.
  8. Tideland Prius
    16,588
    For a moment there I was thinking, "since when did a Toyota Echo work for a home automation jobs?" :LOL:
    ETP likes this.
  9. PriUncut
    268
    266
    Southern California
    Four Touring
    I forgot about that car. Not sure we had it in the States. Think it was (is) the Yaris.
    ETP likes this.
  10. Tideland Prius
    16,588
    Not the Echo hatchback, but you did get the Echo sedan & coupe from 2001 to 2005 before the Yaris sedan (née Toyota Belta) arrived to replace it for 2007 after a 1 year hiatus. The Yaris Hatchback arrived in 2006.
    ETP likes this.
  11. ETP
    2,802
    1,170
    Auburdale FL
    You may be able to get more MPG than me with those skinny tires. I usually get 74 in an empty car driving like me (slower, no AC and a cracked window at low speeds). With a passenger and the AC on mid 60s to maybe 71.
  12. jettlash1000
    51
    All good points! That particular off ramp is a congested part of the highway. I'd love to coast down it, but would get run over in the process. I still can't believe that I can get this kind of mileage without any special efforts.
    The Echo is pretty neat. My wife isn't into technology like I am, and she is even digging it. She doesn't know that it creates cards in the Echo app overtime you ask it something. I found out she was using it when she was home alone through the cards... :)
    #12 jettlash1000, Jun 26, 2016
    Tideland Prius likes this.
  13. PriUncut
    268
    266
    Southern California
    Four Touring
    Ahhh, those were the years I was on a BMW bender :eek:... changing beamers every year (I had a serious problem). So Toyota wasn't even on my radar back then. Now I'm in a 12 Step Program!
    ETP likes this.
  14. Tideland Prius
    16,588
    Wow.
    lol. Probably doesn't require 12 Prii ;)
  15. ETP
    2,802
    1,170
    Auburdale FL
    Two steps around here. Saw a Coral snake slithering into the neighbors yard.
  16. Wolfy90503
    Wolfy90503 Junior Member
    56
    Torrance, CA
    He's getting 70 because all the roads there are flat... unlike here in Calf.
