Bracket sticks out of rear fender wells
Discussion in 'Gen 4 Prius Main Forum' started by sttkailua, Jun 25, 2016.
  1. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    2016 Owners,
    Don't know if this was mentioned in earlier posts, but I did a quick walk around, and
    noticed that a bracket on both rear fender wells don't seem to be flush with the fenders, and
    noticeably stick out. See photo attached.
    Can this be loosened and made flush, or is this normal?
    I would assume factory guys at Toyota would have seen and fixed this?
    Thanks,
    stt
    KimPrius3 likes this.
  2. Mendel Leisk
    41,397
    Can you take a pic from the other side, looking to the rear and up? My guess would be fender liner that should be tucked in, has slipped out. Look at the other side of the car for comparison, might help.
    Stuff like this you can take to the dealership, it being so new. But if it's a simple fix it's often more efficient to just sort out yourself, as long as it's not something damaged or missing.
  3. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    It's normal. I have the same.
  4. booke02
    booke02 Active Member
    391
    415
    Israel
    Another picture would help. Doesn't look normal to me, even if other folk have it too.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I agree, it might be a factory miss. Nothing should be sticking out like that.
  6. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I have it too. I think it's pretty weird they have it sticking out like that, but it isn't noticeable on my black car. I wouldn't worry about it. Maybe it could be a secret for the low drag coefficient.
    pakitt likes this.
  7. Mendel Leisk
    41,397
    Pull it out a bit further, trim, then push back in?
    Is it metal or plastic??
  8. pakitt
    2,173
    1,313
    Colorado
    I will make pics tomorrow and post them.
    It is plastic. Hard plastic. And it is meant to be that way, it is not mounted wrongly.
    Why it has to stick out, I think it might have to do with aerodynamics.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I've seen it before on other cars - it's on my FORD Fiesta. Is it a mudflap, or an aerodynamic aid?
  10. krmcg
    2,592
    2,392
    Whittier, CA
    Me too
  11. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I'd guess that that piece helps keep the flow from the wheels from interfering with the flow along the car?
  12. Mendel Leisk
    41,397
    It's so minuscule, can't see it being an aero aid. I'd suspect it just poor fit. I'd do nothing, at least for a while.
  13. pakitt
    2,173
    1,313
    Colorado
    It's not a poor fit. It is like that. It is meant to be like that.
    If it were a poor fit, the poor fit would be standard world wide.
  14. krmcg
    2,592
    2,392
    Whittier, CA
    I think it works to "mend" the body panel seams together
  15. sttkailua
    190
    151
    Hawaii
    Thanks for the comments.
    In looking at my daughter's 2013 Prius, there is no bracket.???
    Not a big deal for me.
    If it is typical on your 2016's, and even some other brands,
    I'll just not worry about it.
    Now, if wifey says 'shave it down!', I'll take care of it!
    stt
    Coast Cruiser, alanclarkeau and bisco like this.
  16. bisco
    51,892
    what's that round thing in the fender?
  17. sttkailua
    190
    151
    Hawaii
    Side sensor for lane departure, park assist.
    stt
  18. bisco
    51,892
    ah, an area i am unfamiliar with, thank you.
    ETP likes this.
  19. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Just got my Prius 4 today (need to change my name) Mine is exactly like your picture. I think it must be normal.
    ETP likes this.
  20. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    And, if you feel around in there, this feels like it's an extra piece specifically intended to be there (on both sides).
    Really, it's an aero piece. Sometimes it just takes a little bit to keep some flow attached somewhere
    Coast Cruiser and pakitt like this.
