  1. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    So um, when can my Prius have one? :eek:
  2. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Order two please... :D
    orenji, sfv41901, bonchang and 2 others like this.
  3. Xterra72
    Xterra72 Senior Member
    1,437
    1,683
    Hmm @InspectorGadget, do we need more horsepower before this is available for the Prius?:(:D(n):cry:
    bonchang and HelloHybrid like this.
  4. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Build it, and they will come.
    sfv41901, bonchang and HelloHybrid like this.
  5. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    If you want to install a basket handle, yes, you need more horsepower.
  6. Xterra72
    1,437
    1,683
    My favorite, a shopping cart
    Dylan Doxey and Burna J like this.
  7. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    I'm still thinking about getting plug-in grill. hmmm
  8. Xterra72
    1,437
    1,683
    From my experience, if you can't stop thinking about it, more than likely you will be getting it, whether it be now or later. Better now than later. The endless torture is draining. Cha Ching! :D
    #12288 Xterra72, Jun 29, 2016
    aportades, orenji, sfv41901 and 5 others like this.
  9. sd1810
    sd1810 Active Member
    105
    361
    Socal
    2015 Prius Plug-in
    Have @sfv41901 put in an order to custom build it. @Dylan Doxey to do retrofit led the entire length of the wing. @RightOnTime to test on the track and market it while the rest of us keeps staring at it and dream of the "what ifs". :)
    @saulbassfan for the grill just photoshop it first then decide. I don't think you have any silver accents on your car may look odd.
    Anyway, my contribution to this thread since we are all over the place. As @torparts would say "stay on topic!".
    Bought the Tom's Bar from hybridpit.com and powdered coated here in San Diego. Big things coming. Ramen noodles on deck. #phuckthebudget
    #12289 sd1810, Jun 29, 2016
  10. saulbassfan
    979
    3,108
    Southern California
    I'll do some photoshop mockups. That usually gives me a good idea.
    So I finally bought these, via my friend in Japan.
    #12290 saulbassfan, Jun 29, 2016
    aportades, orenji, sfv41901 and 6 others like this.
  11. Xterra72
    1,437
    1,683
    #12291 Xterra72, Jun 29, 2016
    PriiPrii and sfv41901 like this.
  12. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    dont forget to modify the inverter cover or dremel off the top right grounding plate and move it to a different spot. @Burna J would know a good spot. and/or have pics of this.
    sfv41901 and bonchang like this.
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Make it 3 or 4 :D
    iPhone ?
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Sweet. Ur gonna love that bar.....same 1 I got from HybridPit & had my powder coated blue
    iPhone ?
    #12294 sfv41901, Jun 29, 2016
  15. CoolPrius
    CoolPrius Active Member
    218
    291
    86
    Virginia
    2018 Prius c
    granTORRESmo, orenji, Burna J and 3 others like this.
  16. TRVENEMY
    TRVENEMY New Member
    Raleigh, NC
    Will do! Should have them tomorrow
  17. Dylan Doxey
    1,389
    3,459
    92
    Is that bar more stiff than the TRD bar?
  18. InspectorGadget
    216
    450
    Heber City, Utah
    I'd like to know why Tom's and not _________?
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    @Dylan Doxey this is a Strut Tower Bar. Just like a Cusco or Tanabe STB. TRD is the RSB (Rear Sway Bar)
    @InspectorGadget
    In order of best to ok:
    Toms STB: 1 piece Solid Design for minimal to no flex. Clears the Fuse Box
    Cusco: 3 piece bolt together design. Clears the fuse box
    Tanabe: 3 piece bolt together design. Does not clear the fuse box
    I look at it this way......if I'm going to spend the money to stiffen up the chassis by buying a STB to reduce body flex, I want a bar that won't flex. A welded 1 piece bar can handle more tinsel/compressive strength than that of a bolt together bar.
    I've personally owned a Cusco STB & now Toms STB
    iPhone ?
    PriiPrii, aportades, orenji and 5 others like this.
  20. Xterra72
    1,437
    1,683
    @sfv41901 what's the price difference from Cusco 3 piece to Toms 1 piece?
