Unintended acceleration
Discussion in 'Gen 3 Prius Technical Discussion' started by bob waber, Jul 8, 2016.
  1. bob waber
    bob waber Junior Member
    washington
    My 2013 goes 7mph with the foot off the gas.
    Why is it doing this and is there any way to correct this?
    Is this normal?
    I have to keep my foot jammed on the brake to stop the car from lurching forward.
    VERY annoying, this car has a mind of its own....
    Help
    52,334
    no, it's the 'creep' feature. not us owners :p but to emulate an automatic transmission. how long have you owned her? in 12 years, and 3 prius, i've never let them get up to full speed on the flat to see how fast they would go.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    It's called automatic transmission creep. If you really don't like this phenomenon, get a manual transmission vehicle.
    stormchaser, fuzzy1 and Raytheeagle like this.
  4. bisco
    52,334
    or some bev's allow it to be turned off.
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I had a car that would get up to 25mph at idle cold. I don't know where it would have topped out as I had to brake for a stop sign at the end of the street. I remember I had to stand on the brakes or shift in to neutral stopped at traffic lights on occasion. At best that's annoying and at worse it's dangerous.
    I'd be real annoyed if I had that problem with the Prius. I'm now curious. I'll have to remember to check this out "next time".
  6. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Have you ever driven a car with a conventional automatic transmission? If so, didn't it do the same?
    fuzzy1 likes this.
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    How's that unintentional acceleration when every automatic cars out there do it too? Back in high school, I had a class mate with an old El Camino that idles at 2500 rpm. When he released the brake while in D, his El Camino would speed up on its own and up shift on its own. It accelerates on its own to 75mph without him even touching the gas pedal. Now that's unintentional acceleration. 7mph is nothing and is normal.
    Raytheeagle likes this.
  8. mrbigh
    3,686
    699
    Long Island, NY
    It's trying to speed up the car payments...............
    bisco and Raytheeagle like this.
  9. bob waber
    washington
    1. The prius does not have an "automatic transmission"
    2. The cars I have drove did not creep, if they did, the idle speed was incorrectly adjusted
    3. I would not call 7mph "creep"
  10. fuzzy1
    10,602
    Its user interface and 'touch and feel' emulate an automatic transmission, including the familiar automatic transmission creep most people are accustomed to.
    The old, worn, loose 1963 Ford stationwagon I learned on didn't creep either. It didn't even budge until I pushed the gas pedal down halfway.
    The rest of the automatics I've driven did creep. (I personally haven't owned a true automatic in thirty years, just sticks and this eCVT.)
    Many of us do call it that.
    #10 fuzzy1, Jul 15, 2016
    Maarten28 and CR94 like this.
  11. cproaudio
    2,401
    762
    CA
    Look, The Prius came out in 2001. Back then, there were no other cars like it. To make a car that doesn't creep while in drive will get countless complaints about "There's something wrong with my car. It doesn't creep like all other automatic transmission cars out there" So, Toyota made it to creep to mimic all other automatic cars out there. It has not changed since first release. There's no way around that except sell it and get something that doesn't creep when in drive. When I test drove the i3, the first thing I told the BMW rep that there's something wrong with the car. It doesn't creep when I release the brake. That stupid rep didn't know any better and told me that it's a test car. Production version will be different. 7MPH is well within normal range. You can always take it to the dealer but you're wasting your time and pay unnecessary diganostic fees for normal behavior. Prius is CVT and mimics automatic when you release the brake. Did you test drive it when you first bought it or did you bought it sight unseen?
    RRxing, Maarten28 and Raytheeagle like this.
  12. bisco
    52,334
    bob, again, i have to ask, how long have you owned her? if it just started happening, there may be something wrong. if you just bought her, and didn't test drive, trust us, it's normal.
    one other thing that can make it seem worse is the grabby brakes.
    CR94 likes this.
  13. fotomoto
    5,639
    3,815
    So. Texas
  14. ZeroTX
    ZeroTX Junior Member
    64
    Houston, TEXAS
    I'm also not a huge fan of auto transmission "creep" (never previously knew that this concept had a name). Truthfully, in true automatics, it's an unintended consequence of the torque converter, rather than an intentional effect. It would be cool if they would just give you a menu feature to decide if and how much "creep" to have. Nothing (and I mean nothing) is more annoying to drive than an automatic car with a high idle that feels like you have to hold the brake down hard just to sit still. Super annoying. Although the CVT is a type of automatic, I do not think that it has a traditional hydraulic torque converter as regular automatics do, that give them the unintended creep "feature" that people are so accustomed to.
    BTW, my "other car" is a Honda Civic Si 6-speed manual. I often sit at red lights with no brakes if I'm on level ground.... why hold down the brake unnecessarily?
    ZeroTX
    2014 Prius Five
    2014 Civic Si
  15. fotomoto
    5,639
    3,815
    So. Texas
    I have no issues with creep. Sitting at a long light in traffic? I snick into N just like I do with a manual. I think you'd have a renewed appreciation for creep in you lived in a more hilly area than pancake flat ol' Houston. :)
  16. JimN
    7,028
    1,117
    South Jersey
    I had to test this in an empty parking lot that was not level. I could get the car up to 7mph downhill and 3mph uphill. From my perspective that is "creep". It may be annoying and unnecessary from a technical viewpoint but even Tesla discovered they needed to offer simulated transmission creep.
    fuzzy1, fotomoto and bisco like this.
  17. bisco
    52,334
    they had to add hill start assist, because the creep wasn't creepy enough.;)
    fuzzy1, gamma742 and CR94 like this.
  18. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    To conserve battery energy, the creepiness shuts off when you press the brake with sufficient force. That seems to have the unfortunate side effect of making the brakes seem even more grabby at very low speeds than they already are. When you're pressing the brake with gradually increasing force, just as the brakes take hold, the opposing creep force stops, so the car abruptly stops.
    fuzzy1, gamma742 and Maarten28 like this.
  19. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    You can notice the effect very good when your going slow (few mph), brake lightly and then put the transmission in N. All of a sudden the car decellerates a lot more!
  20. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    As mentioned:
    For the Prius - it's normal
    Keep foot on brake - car doesn't move
    Lift foot from brake - car creeps
    On to the next thread!!! (y)
    Maarten28 and stormchaser like this.
