Tree droppings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jul 11, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Hello
    I park my White 2010 Prius under the trees for shade and I did not wash it for over a month
    The trees left a lot of stuff on the paint (no bird poop)
    I washed the car and some markings remained ...I noticed if I rub the spots a little they come off (but it will take some time) so they don't seem permanent.
    Two questions
    What is a good way to get all those little marks off without damaging the paint ?
    What is a good wax I can use to keep the car looking good?
    Thanks folks
    PSI am going to get a car cover so this doesn't happen again
  2. orenji
    orenji Senior Member
    5,887
    3,488
    I would clay-bar the paint, Mothers Wax's has a kit and it cost around $20.00. It is very easy to use and will remove most contaminates from the paint, leaving the paint feeling smooth and soft.
  3. Taxi/Limo
    524
    107
    That is a great suggestion
    I found the Mother's website and their kit is about 30 dollars
    I also found this stuff called Pinnacle Ultra Poly Clay they claim it's the best clay available .
    Any comments on the best clay to use and while you're at it can anyone recommend a good wax ?
    Thanks
    #3 Taxi/Limo, Jul 11, 2016
  4. yeldogt
    yeldogt Active Member
    810
    313
    NE
    They sell bug and tar remover ... I have also used kerosene or lamp oil depending on what I have around. Tree sap can damage paint -- so get it off. Almost any wax will make removing this easier in the future.
    Clay is great -- but it not really for removing large impurities. Remember they get imbedded in the clay. Remove the big stuff first -- they clay.
    #4 yeldogt, Jul 11, 2016
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I use Meguire's but I don't know if it is any better or worse than any other brand.
    I agree with yeldogt. Try bug & tar remover first. Then wash, clay & wax the car. The faster stuff comes off the car the less damage it will do.
  6. orenji
    5,887
    3,488
    You want to try with clay barring first, see if it comes off with the clay bar first. Bug and Tar remove is a pretty strong cleaner and you want to use products that have the least amount of harshness to the paint. It sounds like you have tree sap, and its still fresh, do try to remove it as soon as possible. You should be able to pick up a claybar kit for $20.00 at Pepboys. I like Mothers waxes.
    #6 orenji, Jul 11, 2016
  7. Mendel Leisk
    41,029
    I used a rag wetted with kerosene with a dab of car wax. Worked best for me, dealing with fresh tree sap.
  8. Taxi/Limo
    524
    107
    Thanks for the suggestions I stopped at a body shop today and shop manager rubbed a little car wax on one of the stains and he got 90% of it out
    So I"m wondering what's least damaging to the paint to use wax to rub out the stains or to use clay bar
    Nexus 6 ?
  9. orenji
    5,887
    3,488
    Clay Bar is used with liquid wax. The clay helps pick up particles stuck on the paint, if hand wax removed it, why not just wax your car by hand?
  10. Taxi/Limo
    524
    107
    There's a lot of deposits not just a few that's why
    I was wondering what is best to do first
    if I waxed it and there was some marks left would that be the time to clay bar ?
    Nexus 6 ?
  11. Taxi/Limo
    524
    107
    I should elaborate some of the deposits are stains most are little lumps or irregularities on the paint surface
    Nexus 6 ?
  12. orenji
    5,887
    3,488
    I think you will need to try several products and see what works best. It's hard for anyone to recommend one mothod over another without testing it. You may need to use a cleaner, polish and wax. Plan on having a full day available and shade or garage to work in.
  13. Taxi/Limo
    524
    107
    I did a wash with Dr Bonner soap and used kitchen nylon scrub pad and gently worked on each spot a lot of them came off but now I notice what looks like little white marks where I scrubbed
    Did I damage the paint? How can I fix this?
    Nexus 6 ?
  14. Mendel Leisk
    41,029
    Those nylon scrub pads are quite abrasive. Try something that will act as a tree pitch solvent. Again, kerosene worked well for me, coupled with a dab of car polish. In a pinch any petroleum product will do, say WD40.
  15. Taxi/Limo
    524
    107
    I really didn't scrub but rubbed
    Nexus 6 ?
  16. Taxi/Limo
    524
    107
    OK
    Nexus 6 ?
  17. Taxi/Limo
    524
    107
    That's my next step I tried a little wax and it did not work well so now I need to find some kerosene
    Nexus 6 ?
  18. Mendel Leisk
    41,029
    Any hardware store should it, in little quart bottles. It's kinda similar to gasoline, but less volatile. Used in traditional wick lamps.
  19. Taxi/Limo
    524
    107
    What about charcoal lighter fluid?
    Nexus 6 ?
  20. Mendel Leisk
    41,029
    Probably similar, but more volatile?
    Kerosene is recommended for motorcycle chain cleaning, that's why I picked some up. It's slower to evaporate. Readily available.
    Just looking now on Home Depot, not seeing quarts, just gallons. But should be out there.
