Toyota Prius 2011 fuel consumption problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Arslan Mughal 11, Jul 13, 2016.
  1. booke02
    booke02 Active Member
    391
    415
    Israel
    Tire pressures? Health of 12V battery?
  2. Arslan Mughal 11
    Arslan Mughal 11 New Member
    Pakistan
    Tire pressure is good and battery is also inpected. One more thing sometimes with full battery he will covered 12km and sometime at same condition he will covered just 2 3 km before 1 month this stable every full battery he covered 10km.
  3. booke02
    391
    415
    Israel
    How does the car feel when you accelerate - normal? Maybe there is a fuel leak, or someone stole petrol from your tank?
  4. Arslan Mughal 11
    Pakistan
    Loud sound of engine when normaly accelerate. No leakage in fuel tank.
  5. booke02
    391
    415
    Israel
    Sounds like the electric motor is not doing its job properly. (Bad fuel consumption, low EV range, and noisy engine when accelerating all point in this direction)
    Maybe faulty cells in the hybrid (HV) battery?
  6. Arslan Mughal 11
    Pakistan
    Ok thnxx for the time i will check it from Toyota dealership.
  7. bisco
    51,837
    there is no way you can go 8 km on battery alone in a prius, unless you are going down hill.
    Sheikh John, Maarten28 and CR94 like this.
  8. Mendel Leisk
    41,301
    Plug-In Prius? But that came in 2012? (n)
  9. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    What type of oil did you use?
  10. niazinadeem
    niazinadeem New Member
    Pakistan
    I am experiencing the same problem with Prius 2014, can anyone advise please.
    #30 niazinadeem, Jul 11, 2018
