4th Tank 800.9 Miles, Ave 80.7MPG, 10.2 Gallon, DTE=2miles
Discussion in 'Gen 4 Prius Fuel Economy' started by Mr.MPG, Jul 14, 2016.
  1. Mr.MPG
    Mr.MPG Member
    30
    Southern California
    Four Touring
    This is my 4th tank of gas since March 5th, averaging 80.7MPG on a 10.2 Gallon. Everything else stayed the same as before, the only thing I noticed that was improving my MPG this month was the Temperature was 7 degrees higher, Morning averaging from 70-77F and on the way home averaging from 77-85F.
    Model: Four Touring 2016 Silver
    Drive Mode: Normal
    Tires: 42PSi Front, 40PSI Rear
    52,286
    nice! average speed? calculated mpg's?
  3. tzx4
    tzx4 Active Member
    164
    148
    Wow. The extra surprise is that (presumably) you have the gas hungrier 17 inch tires that comes with the Touring model.
  4. tzx4
    tzx4 Active Member
    164
    148
    I am with bisco. Seeing the display set to show the EV driving percentage and the average speed would be very enlightening. LIke this . . . IMG_1160.JPG Don't take the MPG seriously here, that was all down hill. No way where I live could I get even 70 consistently.
