How to Change Front Map Lights.
Discussion in 'Gen 4 Prius Accessories and Modifications' started by eight08customs, Jan 27, 2016.
  1. gr8mpg
    gr8mpg Junior Member
    Chicago
    I only replaced all interior lights (no exterior) with white LEDs,
    $15.99 from Amazon for a 10 pack that will take care of everything:
    Jim in NC likes this.
  2. gr8mpg
    Chicago
    Partsam 2012-2014 Toyota Prius v White LED Interior Package Deal(10 Pieces)
    krmcg likes this.
  3. Jim in NC
    Jim in NC Active Member
    217
    266
    28
    Myrtle Beach, SC
    Thank you gr8mpg and I ordered the ones you said.
    Although on Amazon it said for Prius v. Do they still fit?
    I hope they are easy to put on. Did you have any trouble?
  4. Patrick Conner
    Patrick Conner New Member
    Muncie, Indiana
    What kind of light did you order for the dome light that is different type of bulb then all the others.. I cant find what to get for that one..
  5. gr8mpg
    Chicago
    They will fit just fine in your 2016 Prius. You will have enough LEDs for:
    2 map lights
    2 door lights
    2 vanity mirror lights
    1 cargo light
    1 dome light (all LEDs are the same except this one)
    You will have one spare dome LED and one spare of the other LED remaining.
    Only the map lights are a bit difficult, but follow the instructions in this forum
    and you will succeed. Go slowly and use caution so as not to break the plastic
    tabs of the map light frame.
    Jim in NC and krmcg like this.
  6. GREEN BAE
    GREEN BAE Member
    58
    48
    Winter Garden, Florida
    2024 Prius Prime
    XSE
    can someone post video on YouTube. pictures are worth a thousand words but video is priceless.
  7. Jim in NC
    217
    266
    28
    Myrtle Beach, SC
    Thanks so much to tahlpaul because I wouldn't have wanted to risk breaking part of my new car!!
    I very carefully studied his pictures, especially the 1st and 4th ones. They show where the clips are located on the ceiling light/control assembly. Then I used this tool which I purchased at Advance Auto to slip under the right front corner and pop the first clip out:
    Then I popped out the left front corner and then the right rear and left rear.
    I had some trouble detaching the wire harness on the left, so I kept it attached.
    Then it was really easy to just turn the 2 bulb sockets, pull out the socket, remove the bulb and replace.
    My kind of bulbs only work with the polarity in 1 direction so I had to test after inserting.
    Then voila! My Prius interior is all LED! Beautiful and bright! The old bulbs are so dim and yellowish looking. And they get really hot too.
    tahlpaul and krmcg like this.
  8. Patrick Conner
    Muncie, Indiana
    The dealer changed mine for free...
    I just installed rain guards last night also
    Fobbers and Jim in NC like this.
  9. Jim in NC
    217
    266
    28
    Myrtle Beach, SC
    Ooooh, nice!
    That gives it a beautiful bluish tint with your white seats. I also like how you took off the plastic wheel covers.
    Where did you get the center caps and how much?
    The vent visors look great also. Mine worked loose after a couple of weeks because the tape was cheap/defective. I got some more 3M automotive tape and put them back on so they'll never fall off. Be watching to see if yours come loose because one of mine almost blew off on the interstate!
  10. Patrick Conner
    Muncie, Indiana
    The center caps were free too from the dealership. And these are 3M and I drive 1 hour on interstate everyday to work and 1 hour back home and they are so tight so we will see.... 20160712_211729.jpg
    Got wwindows tented also as part of the deal when I bought it 20% on back glass <trunk and lower trunk glass> 5% on the 4 side windows and 35% on the windshield all the way down the windshield completely covered. Every car I have had I have done that too....
  11. GREEN BAE
    GREEN BAE Member
    58
    48
    2024 Prius Prime
    XSE
    what is causing the blue tint? I feel like you put a blacklight in your dome. it has that glow. I like it.
  12. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    Dome light
    30mm festoon beware of the LED's that are all round the bulb. no point in lighting the roof space :)[​IMG]
    krmcg likes this.
  13. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    Thanks, just did light in trunk and puddle lights. I used a flat case cracker that I use for taking computers apart. Took a little wiggling on the first one to figure out how to get hood off, but the other 2 were a cake walk after that. Too hot to be hacking the dome light tonight, so that will wait a few days. The big one is the map light assembly, that may be a chore.
  14. krmcg
    2,592
    2,389
    Whittier, CA
    Every one gets easier.
  15. Jacuna
    Jacuna Junior Member
    Chicago
    Hi
    I found this video explaining how to remove the map lights in the prius Gen4 Unfortunately I found it after changing the lights :(. ... It could have saved me a headache! Check it out
    iPhone ?
  16. timdafweak
    timdafweak Member
    35
    46
    Tampa
    2018 Prius
    That's awesome! Thank you very much for posting it. Does anyone know where one can get the strip of LEDs like in the video?
    Fobbers, JayNWArk1977 and Jacuna like this.
  17. Jacuna
    Chicago
    #57 Jacuna, Aug 27, 2016
    RCO and timdafweak like this.
  18. timdafweak
    timdafweak Member
    35
    46
    Tampa
    2018 Prius
    RCO likes this.
  19. thunderstruck
    154
    151
    Port Charlotte, FL
    2022 Prius
    Looks like I'm running into what you saw. I have a 3 with ATP. I used an auto trim tool but it appeared only the bezel would come off if I had kept pulling. Not entirely sure if I have the same 4 mount points as detailed on P1 or not. Anyone have any advice on doing it on a 3? Don't want to crack it or ruin it. It's back as is for now.
    RCO likes this.
  20. Dorkytom
    Dorkytom New Member
    Orange county, ca
    I did interior leds also following this thread.
    I also did floorwell and glove compartment, which were even easier, though I didn't bother buying the special leds in the bracket. I used a led panel which I stuck on with 3m attachment tape routing it through the original bracket whole to the wiring. They dim well when in gear. It's dumb how toyota chose to tie the glove compartment led to the headlights.
