downloading phone book
Discussion in 'Gen 2 Prius Audio and Electronics' started by smurf041, May 27, 2006.
  1. smurf041
    smurf041 New Member
    Prius delivered on Thursday. Was able to connect to phone but unable to download phonebook. When trying to transfer, bluetooth disconnects but screen on vehicle says transfer is in progress. Can you help? Phone is motorola E815.
    Smurf
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(smurf @ May 27 2006, 08:45 AM) [snapback]261771[/snapback]</div>
    Verizon disables the phone book transfer feature on its phones.
  3. compchat57
    compchat57 New Member
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ May 27 2006, 11:22 AM) [snapback]261782[/snapback]</div>
    Transfer each number individually. That's what I did.
  4. Kross
    Kross New Member
    88
    Pittsbugh, PA
    <div class='quotetop'>QUOTE(smurf @ May 27 2006, 11:45 AM) [snapback]261771[/snapback]</div>
    Yes, as mentioned above, Verizon loves to disable BT features on the phones. Pushing over the whole phonebook at once is unfortunately one of them.
    I think for your phone you can push over the contacts one at a time.
    What you have to do is:
    - Go into "Settings" from the Phone screen on your Prius' MFD (the screen where you have the dialpad)
    - Hit "Transfer Data", "Add to...whichever group you choose", and then the Prius will say something along the lines of "Waiting for transfer. Transfer from your phone".
    - That is when you go to your cell phone, go to the contact you want to send over, go to options, then look for an option along the lines of "Send Contact through Bluetooth" and then select the paired device to send it to (in this case, the Prius, which shows up as "Handsfree" as default I believe).
    Of course in a 2006 you could just enter the contacts in manually straight to the car :)
  5. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    Verizon Motorola e815 cannot transfer phone contacts period--including the hacked version.
  6. Kross
    Kross New Member
    88
    Pittsbugh, PA
    <div class='quotetop'>QUOTE(wesj49 @ May 30 2006, 10:58 PM) [snapback]263195[/snapback]</div>
    oops, in that case, nevermind my loooong post above :unsure:
