  1. Krish Udvadia
    Krish Udvadia Junior Member
    Westlake Village
    What do you mean by empty it
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    usually a little bit of oil accumulates there between oil changes/
    if you look at a 'regular' catch can you can see that most of them have a little screw or something alike at the bottom to empty it/
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Well, if it's an oil catcher, it is designed to collect oil. So one might inquire how to empty or remove the collected oil at some point? ;)
  4. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    If you're concerned enough about oil in your intake tract to install a catch can in the first place, being able to drain any accumulated oil makes sense.
    I'll be curious to find out how much oil your catch can catches.
  5. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
    I had two options in mind either remove the breather filter and just snake in a small hose attached to a shop vac and suck it out, or I tap in one of these valves in the middles. I'm probably just going to shop vac the oil out since I'm assuming it will probably fill up maybe once to three time a year?
    Maybe after a few weeks of testing it in the summer heat I'll consider putting out a small series.
    Oil vapors comes from the hose attached to the top of the valve cover which is push out by positive crankcase ventilation. In the OEM set up that is usually sucked up back into the engines intake causing oil to build up within the intake manifold.
    Here's a better explanation of it Oil Catch Cans | Everything you need to know and more!
  6. 2ZR JDM
    106
    142
    Redondo Beach
    Same here, the amount varies mostly on the health of your piston rings.
    I'll let you guys know when it actually fills up. (y)
    Dylan Doxey likes this.
  7. Almasy
    Almasy Junior Member
    Garden Grove
    Yes It's Android 444
    No I tried. It's too big :(
  8. Almasy
    Garden Grove
    my Prius looks weird now :cry:
    Here is the video.... you can see what's inside my car
  9. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    Does anyone know if they make led turn signals like the gen3 side mirrors for a gen2?
  10. Jk818
    Jk818 Member
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Where is that fool who wrote in his blog about Prius' being "lightly" modded? He should see your line ups!! Looks like a fun day for all!!
  12. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    The only way to satisfy someone like that is to put a supercharged V8 in a Prius. Oh wait, that wouldn't satisfy them. Instead they would ridicule the Prius with a supercharged V8.
  13. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Today I starts next phase of modding in preparation for the Aug. 20 Stancenation Nisei Showoff car show in Little Tokyo, LA.
    Dropping plug-in grill I got from @RightOnTime to get painted today.
    Here's what's gonna happen in the next month:
    Eat Cup O' Noodles for a month
    Engine covers, including CT200h valve cover
    Hood struts
    Finish Remin Dash Kit on doors
    Install Clazzio material on doors (thanks @HAWAIIANBUILT )
    Junction Produce Type A pin-stripe
    Wood laminate floors in trunk setup
    Android to I-pad mini swap head unit
    Prius G's brake pedal
    Respray front lip and clear bra it
    Reinforce rear bumper spoiler lip to bumper
    Try to tweak suspension more
    Maybe new tires
    Get sick from eating Cup O' noodles for a month
    Mostly jobs for Masta S. @sfv41901
    #12613 saulbassfan, Jul 20, 2016
    RightOnTime, PriiPrii, Jk818 and 7 others like this.
  14. sd1810
    sd1810 Active Member
    105
    361
    Socal
    2015 Prius Plug-in
    Dont forget the soft boiled egg homey.
    #cuponoodlesforlife
    torparts, PriiPrii, orenji and 4 others like this.
  15. saulbassfan
    979
    3,108
    Southern California
    Dats pancy!
    torparts, PriiPrii and sfv41901 like this.
  16. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
  17. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    ^ Interested in this ^
    PriiPrii and Dylan Doxey like this.
  18. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    looks great! I have had that back bumper on my ebay watch list for the longest time, lol. it has always been that, the seibon CF one, or #secretstuff. But im glad someone on PC has finally got the all around kit! Im excited for the finished product!
    If I may weigh in my 2 cents, I think itd look sick in a matte color. ;)(y)
    Burna J and Accordlayingkit like this.
  19. Montgomery
    2,254
    2,241
    Orange County, CA
    I absolutely love what you did! Definitely a one-of-a-kind mod!! You have an eye for contrast and it shows. I think you did great!!!
  20. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Hey fellas haven't done much modding lately but love to check the forum often for new ideas.
    Burna J likes this.
