Fill Up when Tank is Empty, Quarter Full or Half Full?
Discussion in 'Gen 4 Prius Fuel Economy' started by Marshmallow, Jul 20, 2016.
  1. When I'm On Empty
  2. When I'm 1/4 Tank Full
  3. When I'm 1/2 Tank Full
Results are only viewable after voting.
  1. Marshmallow
    Marshmallow Junior Member
    this prius is the first car that i ever bought, with that said, i want to take care of it as well as possible.
    i drove my first car to empty, once the range was at 0, i drove an additional 5 miles or so before filling up. i paid for 10.3 gallons, so i guess that a gallon was left in the reserve. anyway...
    this guy told me that it's not good to drive your car until it reaches empty, and so after doing some research, i came upon this article:
    [can't post link since this is my 2nd post, but i will later if anyone is interested]
    knowing this, is it even worth driving your car to empty, or even using the gas in the reserve? i know that it's fun to share how many miles you get per tank (for me, first tank was 645.2 miles with 62.6mpg, which i loved!), and i was hoping to keep running the tank on empty to see if i'm getting better at it, but what's the point if i'm risking damaging my car?
    again, i just bought this car, and i plan to keep it for 10 years (at least try to). the report says that it's best to fill up once you're at a quarter left, but a part of me wants to fill up on gas every time i reach half way. yeah, i might have to fill up twice a week, instead of once a week, but i'll be spending around $15 for every fill up, instead of $30.
    so what is it? fill up on empty? fill up on quarter? on half? what do you do and what do you think of the article above?
    ETP likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    None of the above. Our fuel varies considerably in price (in the last 4 weeks it has varied between $1.10 (today) and $1.34/litre). I fill up when it's cheapest. if I'm below 2/3 full.
    I never let it get to empty - when the indicator says 100km to go, that's about the least I allow it to get. My daughter ran out of fuel once, and it cost me $324 (2002 dollars) to fix.
    ETP likes this.
  3. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    In my experience, the leading cause of fuel pump failure is a poorly designed fuel pump. The only fuel pumps I've ever replaced were on an Escort and a Cavalier, and can say for sure the Cavalier was never run extremely low of gas. My wife regularly ran her Mazda past the point where the fuel light came on and the fuel pump never failed. She also accelerates hard before the engine is up to normal operating temperature and has never worn out an engine. Point is most people don't worry about these things and don't have problems.
    Running the gas so low that the fuel pump is starting to suck in air bubbles is certainly not good for the pump, but at that point the engine will start to stumble and your bigger worry will be making it to the gas station before you run out completely. If you do this regularly, you will probably be coasting to the side of the road quite often. That is, unless you have an old pickup truck with dual gas tanks, where you can switch to the other tank. Note that owners who did that regularly did have problems with fuel pumps.
    I try to fill up around 1/4 tank. Not 1/4 tank on the fuel gauge which is usually pretty conservative, but 1/4 of actual fuel remaining. On my Prius this would be just before it goes down to the last bar on the fuel gauge, or about a 9 gallon fill-up on an almost 12 gallon tank.
    ETP likes this.
  4. Mendel Leisk
    41,301
    I fill up whenever it's below 1/2 full on the gauge (I voted 1/2 tank) and passing by a Chevron. A few reasons:
    1. Our consumption is very low. Even filling up that soon, it's every 3 or 4 weeks.
    2. I want to be the one filling up; it ensure my tank-by-tank mpg tracking stays "on track".
    3. It's ultimately the most convenient, at least for me: don't want to be sweating, make extra out-of-the-way runs just to fill up.
    ETP likes this.
  5. bwilson4web
    16,186
    I fill up when below the last gallon unless I'm at Costco buying something else and have the time.
    But things have changed. It is possible I may have found a replacement.
    ETP likes this.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I like to fill up at 1/4. With a 100+ round trip commute, that's every 3 days. But I'm not religious about and have no issues with driving until the last PiP blinks and DTE says 0.
    You don't have to give up on maximizing a full tank distance. If you notice you are getting great fuel economy on the current tank, then go for it. If it has been a particularly bad tank then fill up at a 1/4 as usual. That's what I do. The recommendation to prolong fuel pump life is to not run low on fuel all the time. Every once in awhile is fine.
    ETP likes this.
  7. ETC(SS)
    7,133
    I always wait until the warning beeeeeeeep and then leisurely (within the next 50 miles) get gas at a clean station with nice, healthy snacks.
    I can't speak for the G4, but the G3 has close to 100 miles of fuel left after the low fuel alert.
    YMMV
    ETP likes this.
  8. krmcg
    2,592
    2,392
    Whittier, CA
    I hesitate to post here because it will bring out the naysayers.
    I have filled my tank 15 times since I bought the car, the average fillup is 10.5 gallons. I have not yet filled my tank before the DTE has reached "0". Average miles per tank is 688.
    alanclarkeau and ETP like this.
  9. ETC(SS)
    7,133
    Naysayers?
    I don't get it.
    Why would somebody flop and twitch over how YOU fill up YOUR car??
    My G3 is a work car with 103,000 miles....with probably 102,500 driven by me personally.
    The only time gas has ever been added to my car before DTE=0 was when it left the dealership and when our contracted wrench swingers top off the car after maintenance.
    Sounds like you're doing what I've been doing for about 5 years now....
    ETP, fuzzy1 and krmcg like this.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Occasional exceptions.
    But most often.
    Gen 3 Prius.
    I wait until the last pip...blinks..with warning...and DTE, cruising range to 0.
    Then I find a gas station and fill up. Never feel rushed, or that it's an emergency. Always has had a gallon or more left.
    Caveat as usual, your vehicle may differ.
    Plus, I live in a pretty urban and developed area, which means once I reach 0 with my distance to empty, I'm going to be able to find a gas station pretty easily and quickly.
    If I'm traveling "where the hills have eyes" or take the short-cut that the old man at the small grocery story warned me not to take? That is, in an area where gas stations may be far and few between, I obviously do not apply this protocol.
    ETP likes this.
  11. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    The fuel pump story is closer to an urban myth than fact. Before modern fuel injection, most fuel pumps were external and many were installed in the engine bay. Talk about heat. Internal fuel pumps are cooled by the fuel running through them. By design motorcycle versions are routinely above the fuel line. Finally, once the fuel rail is pressurized, the fuel pump only needs to run intermittently.
    CR94 and ETP like this.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I only have gas stations every 54 miles so if I have less than 50 DTE I get gas. But I drive a very predictable route over level ground.
    I expect that the Gen 4 has a very accurate, very conservative gas gauge, as Toyota burned the Gen 2 owners and still has not heard the end of it. (if you were buying a used Gen 2, I would be an adamant 1/4 tank guy)
    'Social' reasons to fill up, it is much worse to be a stranded female than a stranded male. Do you travel in neighborhoods you would not want to be stranded in? Do you have passengers that you would hate to hear tell about the time you stranded them? Over and over? Do others drive your car you do not trust to check the gauge? (Or have money to buy gas?)
    alanclarkeau, ETP and fuzzy1 like this.
  13. fuzzy1
    10,402
    All of the above, and more, depending on circumstances.
    Just before entering Canada or California, I'll fill up even when the gauge is at 80%, because the prices ahead are a lot higher. (Except on the east side of Glacier National Park, where prices this past winter were even higher than in neighboring Alberta.) Leaving those areas, I'll go 50 miles beyond DTE=0 unless weather is foul.
    For trips elsewhere, it depends on a variety of circumstances: what gas price patterns I find on GasBuddy; what foul weather (low mpg) conditions are expected; how much safety margin I feel comfortable with under these conditions (1 to 4 reserve gallons), what external drag is added (bike or ski rack); and how far away the next expected service is: Now that I am retired from commuting, the car doesn't get enough miles between trips to need a fillup rule for home.
    #13 fuzzy1, Jul 20, 2016
  14. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    For me personally, I just think it's wise and good common sense to never let my fuel go below 1/4 tank. You never know what kind of crazy sh*t is going to happen in Southern California... and I don't want to be caught sitting in a car that's running on fumes.
    lar.smith42 and ETP like this.
  15. booke02
    booke02 Active Member
    391
    415
    Israel
    nextgas.jpg Would cause a problem to those waiting for DTE to reach zero?
    pakitt, alanclarkeau and ETP like this.
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    15 years ago, you could drive NV140/OR140 from US 95 to Adel Oregon, without passing any houses, let alone gas stations, about 140 miles.
    At one point you can see Denio NV in the distance but you don't get there. (pop 47)
    I have not driven since 2001, it may have changed.
    #16 JimboPalmer, Jul 20, 2016
    ETP likes this.
  17. ETP
    2,802
    1,170
    Auburdale FL
    Fill up where there is cheap gas and I need to do the deed, but never empty. Don't ever go there.
    #17 ETP, Jul 20, 2016
    alanclarkeau likes this.
  18. RRxing
    RRxing Senior Member
    2,545
    1,820
    NEPA
    MPG matters, not MPT...
  19. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I live in the rolling foothills of the Sierra near Yosemite. It's a 25 mile round trip to get gas. During the summer months we have fire season. I've been evacuated from my home a couple of times. It's just wise to be prepared. I try to never let my tank get below half in any car and I fill up nearly every time I pass a gas station. That isn't that often.
    ETP, alanclarkeau and bisco like this.
  20. bisco
    51,837
    i guess the answer to o/p's question is, do whatever works best for you.:p i do think the manual recommends fueling at least by when the last pip blinks and you hear the chime, dte = 0. the emergency reserve is there just for that, emergencies.
    it's important to know the area you're in, if you don't fuel up sooner, although, entune may make unknown area's easier with gas finder.
    ETP likes this.
