help with replace smart key fob shell
Discussion in 'Gen 2 Prius Technical Discussion' started by bensal, Jul 7, 2016.
  1. bensal
    bensal Junior Member
    Israel
    I've Toyota Prius 2008 GLI with just one smart key.
    the case started to flake.
    I've ordered New Keyless Smart Remote Key Shell Case Fob 2 Button for Toyota Prius 2004-2009
    I saw couple posts and videos about the replacement of the battery but not the whole case. I know that's the difficult step is to take out the transponder and put it in the new case.
    do you think that I can do it by myself? or it just don't worth the risk of damage the only key i have.
    thank!
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If you have the proper case, it shouldn't be too difficult. Of course, the fact that you have only one fob makes it even more high risk that you do it properly. ;)
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Be sure to transfer the transponder chip as well as the circuit board. The Gen2 keyfob can be opened by expanding a needle nosed pliers in the mechanical key space. You have to break the glue seal.
  4. bensal
    Israel
    Ok so I replace the key shell and it was very easy! the smartkey is working and everything work fine.
    thank you everyone!!!
