differential oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bryan11, Apr 24, 2006.
  1. bryan11
    bryan11 Junior Member
    Ok, the manual says to inspect the oil but how do you check the differential oil?
  2. bryan11
    Surely someone has checked or inspected the differential oil as it states in the maintenance schedule. From what I've read in the manual, it states to inspect the differential oil every 30,000 miles but I don't see any form of dipstick for it.
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    You have to remove a filler plug on the front of the transaxle and
    check that the fluid level is up to just under the level of that
    hole. May be slightly messy. Removing some of the plastic under-
    cover first is probably advisable.
    _H*
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Toyota recommends a visual inspection for leaks. No leaks oil level=Ok
  5. grimbasement
    grimbasement New Member
    <div class='quotetop'>QUOTE(Frank Hudon @ Apr 24 2006, 09:01 PM) [snapback]244603[/snapback]</div>
    I noticed a couple of drops of in my garage that seemed to come from the rear of the car. The fluid looked like hershey's syrup had no decernable smell but with only about 3000 miles on the car I wouldn't expect funky odors. I tried to look up under the car but it's way too low to the ground to see much. I was hoping it was just something I picked up off the road but I'm thinking I have a leak.I just noticed it for the first time today I cleaned up the spots and will watch and see if it happens again. I may be taking it in for service a bit early. :(
    Any ideas what it could be? I would appreciate any insight others may have.
    06 package 7
    puchased April 26 2006
  6. hobbit
    4,089
    469
    Bahstahn
    the *rear*? There aren't any fluid reservoirs back there except
    the gas tank, as far as I know. Make sure it isn't brake fluid...
    _H*
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(grimbasement @ May 29 2006, 06:59 PM) [snapback]262560[/snapback]</div>
    Blood. Fess up or we will need to make a call. Its OK to hit anything small as long as you have not damaged your car. If you damaged the car it may not go well for you. BTW if you have a differential ( I need a ruling here, do we have a differential?) it is in front. There is this chain tinge and reduction gears. I guess that might be a differential?
  8. grimbasement
    <div class='quotetop'>QUOTE(hdrygas @ May 29 2006, 11:10 PM) [snapback]262595[/snapback]</div>
    I looked this morning and no new drops of fluid on the garage floor. I havn't hit anything that I know of. My wife could have but I'll withhold that judgement until I'm able to see if the problem persists or if there is even a problem to begin with.
    I didn't think there were any reserviors in the rear of the car but that's where the spotting was. I thought brake fluid at first but It's been years since I've done any real work on my cars and unless my memory is bad, brake fluid is clear not chocolate colored, correct?
    At the very least I'm a little worried because a 1 month old car shouldn't be leaking anything.
  9. tochatihu
    tochatihu Senior Member
    9,797
    3,772
    Kunming Yunnan China
    2001 Prius
    <div class='quotetop'>QUOTE(grimbasement @ May 30 2006, 07:58 AM) [snapback]262710[/snapback]</div>
    I would call it "transparent light straw". See color sample in your brake fluid reservoir. Note the fluid level there, since you're looking.
