Reported mileage way off (too low)
Discussion in 'Gen 2 Prius Fuel Economy' started by zzhumphreyt, May 29, 2006.
  1. zzhumphreyt
    zzhumphreyt New Member
    Rock Hill, SC
    I just filled up at the gas station and the pump stopped at 7.485 gallons. I thought this was odd since my car had the low fuel indicator on so I was sure I needed to put about 10 gallons of gas in there, but 7.485 was all I could put in. When I started my car up it showed the fuel, bladder I guess, being full. Now this seemed very odd to me because I had driven 520 miles since my last fillup so this means I got 520 / 7.485 = 69.47 MPG!? I'm not really complaining but I'm just kind of shocked I would get this high since the display said I was averaging 51.6 since my last fillup. That's a huge mileage difference from what I calculated. Has the display been this off for other people? I'm just curious.
  2. qbee42
    3,081
    There is so much variation in the fuel bladder that you can't make any sort of calculation based on one tank. You'll need to total the mileage over many tanks to get a reasonable calculated value.
  3. zzhumphreyt
    Rock Hill, SC
    I guess the gas bladder is the culprit here. At my last fillup the display reported 51.7 but I calculated 55.85. Guess I'll just go on lifetime average more. So far I'm at 49.11 since I got it in late January.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I am starting to do a three tank average on my spread sheet. I may need to go to four. My normal observation is one of a short lived high that come close to the calculated average, followed by falling MPG for the second third of tank or so. After that the MFD average very slowly rises to a final that tends, but is not always, a bit below the calculated average for the tank. In very cold weather the MFD reads a bit high.
  5. ErikU
    ErikU New Member
    97
    DFW area
    I'm very new at this since I haven't even filled up once but I know there are some discrepancies with the MFD mileage....I only have about 220 miles on the car but have noticed that the MFD is displaying 212. I got the car and reset the MFD when it had 3 miles on the odometer so there are 5 miles unaccounted for. I'm going to have to see over time but I think there are just some optimistic errors with what the car reads overall. I would recommend what I am planning on doing and just refill when I am told to do so and then do an overall calculation to see what mpg I'm actually getting. As far as the low gallons of fuel needed to refill the car, I have read that refilling on inclines/declines do affect the tank display. Good luck to you!
  6. ghostofjk
    ghostofjk New Member
    979
    It IS unusual for the bladder to be unable to accept that much of a difference---in normal-to-warm weather. I have heard of almost that much shrinkage in cold weather. Thus I'd say the automatic shutoff on that pump is suspect. The only other possibility was an air pocket in the filler neck, but I doubt it. Assume you tried to keep pumping a few times, with it repeatedly clicking off.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I just had a similar experience. 3016 miles/53.49 gal=56.38 mpg. Way to high I think, the consumption monitor gave me an overall average of 52 to 53 for the entire trip. That would indicate a 4 gal difference between the first and last fill up. To much I think, I might believe 2 gal but not four. My experience with the car after 15K miles leads me to believe my milage was closer to 52 than 56 but I can't explain the discrepancy. I would love to think I got 56 mpg for the trip but I don't think I did.
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have to say that sadly I have manipulated the bladder? (It is OK for those of you that have done the same to come foward) I have waited for a cold day to fill up knowing that it would make my "calculated" MPG higher than on a warm day. Of course in the end I know that it averages out, but I can not resist the total high of the MPG that is over average. Can you forgive me, my brother and sisters?
  9. berylrb
    berylrb Member
    308
    san francisco?
    I don't hdrygas you were my hero you know ... OK you're forgiven!
    b
