Rear caliper seized and service questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaywinston41, Jul 29, 2016.
  1. Jaywinston41
    Jaywinston41 Junior Member
    Just brought my car to Firestone for an alignment and asked them to check on a squealing noise.
    They said the right caliper was seized up.
    Their recommendation was to replace the caliper in pairs, so both rear calipers.
    Then they recommend both brake pads and rotors in the rear.
    They said the front brakes were worn to 3 and recommended replacing front brakes and rotors at the same time.
    I'm skeptical because Prius brakes tend to last forever.
    I have 98,000 miles.
    Im not questioning their assessment of the rear caliper being seized.
    My question is- does a Prius need to have calipers replaced in pairs?
    If a caliper needs replacing should the brake and rotor definitely be replaced as well?
    I'm going to get a second opinion first anyway, but thought I'd ask. I wondered if the Prius braking system might be unique enough to not warrant the typical service or replacement of a normal car.
    I wonder if I should pay the $125 to bring it to Toyota for a second opinion or do you think going to my local mechanic for a second opinion would be enough?
    Thanks
  2. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Get a second opinion -- the caliper get get hung up on the pin vs the piston sticking. It may have destroyed the rotor or the caliper (heat). In your situation -- I would not replace the other caliper if the OE is available or an OE rebuilt. Often when the calipers go -- the car is old and the other side is not far behind or the caliper is different. If it was stuck -- you may be able to salvage the caliper.
    The fronts can go down to 1mm -- you have time on them. Make sure all the front pads have the 3mm. Sometimes one can be less -- no point in trashing a rotor. Do you have a local mechanic? The chains like to change everything .. more $$
  3. Mendel Leisk
    41,850
    The rear brakes are complicated by the parking brake function. It's important that the pin on back of the inner pad locks in between the spokes on the caliper piston face. When the parking brake is applied, if the pin is not solidly locked between the spokes the piston will rotate, the pin will ride partially up on a spoke, and from then on the brakes will be partially jammed, and the pressure when they're applied will be uneven.
    If this is happening the inner face of the rotor will have about 1/2 it's width unused and rusty, and the pin on the inner pad will look chewed up.
    If you're seeing this, I'd try removing the rotors and "dressing" them with sandpaper or steel wool, clean and lube the caliper pins, and install new Toyota pads/shims. New shims are not mandatory, but they don't cost much.
    At reassemble, it's crucial to rotate the piston so that the pad pin falls between spokes. After assembly press brake pedal multiple times to seat the pads, lock the pin. Then reconnect 12 volt (it should be disconnected at the outset). Then do a short test drive. Then apply parking brake as needed.
    If the rotors had a rusty zone the brakes will likely be noisy at first. This may persist for a few days, gradually diminish. You can check if the drag has been fixed, by raising the rear and test spinning the wheels.
    Again, this may or may not be the issue, but it's a cheap first step, needs doing anyway.
    Robert Holt likes this.
  4. bisco
    52,337
    it's important to educate yourself, as you're doing here. the rear brakes can be funky as mentioned above. wherever you go, make them show you what they are talking about. take pics and post them here, if you care to. all the best!(y)
  5. Mendel Leisk
    41,850
    Here's Toyota instructions on brakes, might help your mechanic.
    Robert Holt and bisco like this.
  6. Jaywinston41
    Thanks everyone. Unfortunately I have zero ability to work on this myself so I will need to trust a mechanic. I'm going to my dad's trusted mechanic and I'll have them give a second opinion and maybe pass along some of this info. I guess the point I'll take from this is that Nick doesn't need to be an all-or-nothing deal if not everything needs to be replaced.
    Hoping to keep this a reasonable cost.
    Thanks!
  7. bisco
    52,337
    all the best!(y)
  8. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I do all my own work, and replace just what is necessary. No sense replacing a caliper that isn't bad. Replacement calipers are used refurbs anyhow, so I'd rather have my working OEM. The rotor likely needs replacement if the brake was seizing. This can easily be checked with a caliper to measure thickness.
    I'm more comfortable having someone else change my oil, since the job is easier, and I can observe what oil they are putting in and verify the level. Brakes are more tricky, and it isn't as easy to see if they did it right. Not only that, but the service costs too much. For those reasons, I do 'em myself. Only basic tools are required, and in a pinch, you could even use the tire iron and jack that came with the Prius to do the work.
  9. ChapmanF
    18,486
    Toyota sells refurbishing kits for the calipers if it's needed, so if you don't mind a little DIY, you end up with your OEM calipers all refurbed with OEM-spec rubber for the same money as cheapo aftermarket refurbs; the kit even comes with a little pouch of the Toyota-spec, lithium base glycol grease.
    For the rears, it's odd though, at least the online parts diagrams do not show a replacement for the seal around the parking brake shaft. All the other seals are in the kit. Seems like if there's ever a leak around the parking shaft, replacing the whole caliper is the only Toyota solution.
    -Chap
  10. Jaywinston41
    Well folks, brought it in to my dad's trusted mechanic and they came to h conclusion that the calipers themselves don't need to be replaced, but some sort of slide mechanism was seized and they need to take off both rear ones to clean the rust and grease them up. They did say the brakes and rotors were in need of replacing because both rear caliper slider thingies were rigid. And they also said the front brakes were the lowest they had seen on a Prius at my mileage so recommended replacing.
    But without replacing the rear calipers the job Is half the price of the original assessment. Will be done tomorrow. .
    Thanks!
    Raytheeagle, Mendel Leisk and bisco like this.
  11. bisco
    52,337
    sounds right, the slide pins should be inspected every 5k and lubed as needed.
    Jaywinston41 likes this.
  12. Mendel Leisk
    41,850
    5k is a bit much, every couple of years is reasonable.
    #12 Mendel Leisk, Aug 1, 2016
  13. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Sounds like Mendel has made another successful addition to his convent:)!
  14. yeldogt
    810
    313
    NE
    Glad to hear -- if you read my description ... that is what I was talking about. The Toyota caliper design is subjects to sticking .. this is not usually a problem with cars used regularly .. used infrequently or those that spend time in a harsh environment have a greater chance of this problem. My cars are used most days and get inspected at least twice a year -- I have never had this issue.
    I replace any questionable rotor -- not worth having any future issue.
    Sound like you are on the correct track.
