  1. Xterra72
    Xterra72 Senior Member
    1,434
    1,681
    @xliderider, I thought the same thing after I put it on the steering wheel. I already purchased it, so I might as well use it. Definitely takes getting use to. :D
    Once I have $$$$ to spend, maybe an upgrade from Japan. (y)
    @andino, might need your help on this one.:whistle:
    #12721 Xterra72, Aug 2, 2016
    andino likes this.
  2. Lit Lit
    Lit Lit Active Member
    104
    340
    Northern California
    Look who wants to join the party!
    iPhone ?
  3. Lit Lit
    104
    340
    Northern California
    #12723 Lit Lit, Aug 3, 2016
  4. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Really like the smoked tails with our color car. Just fits better.
    HelloHybrid and m3pare like this.
  6. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    Lit Lit....
    WOW.....your ride is S.A.F. ;)
    Johnsk93, Lit Lit and saulbassfan like this.
  7. Lit Lit
    104
    340
    Northern California
    Thanks! It's a working progress
    iPhone ?
  8. priusrick
    priusrick Member
    257
    40
    uploadfromtaptalk1470270349719.jpeg saw my first new prius.
    SGH-M919N ?
  9. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    Here we go again testing out a new JDM LED Foglamp Kit for Angry Panda! At 2.2lbs each this is a very solid kit which includes built in heat sinks - with the instructions in Japanese warning you to properly aim the lights or it will blind drivers :eek::eek: Another Guinea Pig experiment :LOL::LOL:
    #12729 RightOnTime, Aug 4, 2016
  10. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The problem with the JDM spec lights are that they are setup for driving on the left side of the road, so the beam pattern isn't ideal for driving on the right side of a 2 lane road, as we do in the US.
    Lit Lit and RightOnTime like this.
  11. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    This might be a simpleton's solution, but what would happen if you trade lights or lenses left and right?
    RightOnTime likes this.
  12. xliderider
    8,140
    3,277
    Honolulu, HI
    The housings/lenses are angled outward from the center of the vehicle, so swapping mounts, lenses, or housings isn't possible.
    InspectorGadget and RightOnTime like this.
  13. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    Hahaha! I knew you were going to chime in @xliderider:D Will keep you in the loop for the install, but remember these lights have the same mounting position as my Toyota OEM foglights with the option of adjusting the polar axis. Only time will tell! Thanks for your feedback it is greatly appreciated (y)
  14. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    @xliderider :cool: Since a majority of Manufactures' that produce fog-lights for the Prius are from another Country, could they all be aimed at the wrong side? Food for thought or just overthinking :cautious:
    #12734 RightOnTime, Aug 4, 2016
    orenji likes this.
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm gonna be very optimistic here & say that based on the pic it appears to be a flat cutoff which would be correct for a fog light.
    Time will tell
    iPhone ?
  16. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Tested laminate / vinyl swatches for trunk setup. Pulled the trigger on a case of TrafficMASTER Allure in ironwood.
    orenji, RightOnTime, apt5020 and 4 others like this.
  17. Almasy
    Almasy Junior Member
    Garden Grove
    Went to a car meet last night. So many people curious. I also heard someone said "Wth a prius??" lol
    13920603_10206463640217182_4781724844484992116_n.jpg 13925150_10206451408111387_8028154769244384990_n.jpg 13925577_10206458267962879_4365302486922467483_o.jpg
  18. Lit Lit
    104
    340
    Northern California
    Easiest mod I've ever done lol update Entune App
    #12738 Lit Lit, Aug 5, 2016
  19. FinToy
    FinToy Active Member
    145
    141
    Finland
    Should throw this in today. I'm pretty sure someone else has done it before; did you notice any changes? Better MPG, anything?
    saulbassfan and Accordlayingkit like this.
  20. xliderider
    8,140
    3,277
    Honolulu, HI
    Yeah, a lighter wallet. ;)
    I like the idea of this washable, reusable and oiless filter.
    #12740 xliderider, Aug 5, 2016
    Dylan Doxey likes this.
