New engine splash shield
Discussion in 'Gen 3 Prius Accessories and Modifications' started by trip1027, Aug 3, 2016.
  1. trip1027
    trip1027 Member
    106
    27
    wyoming
    So I am tired of replacing my plastic splash shield for 360$ so I got the local welding shop making a steel one today
    SM-N920V ?
    Robert Holt likes this.
  2. Mendel Leisk
    41,873
    What was failing on the plastic one, the flap at the oil pan I'd assume? Post pictures?
  3. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    once you have it, mind to take some pictures before you install it?
  4. trip1027
    trip1027 Member
    106
    27
    wyoming
    No that never happened, I take my car on some pretty bad terrain and it usually getsome ripped off by a rock or something.... so I'm beefing it up
    SM-N920V ?
  5. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    After working underneath and seeing how flimsy it all is , I can understand making a metal one. I think you might also get a more laminar airflow underneath and perhaps better efficiency .
    BUT, I was concerned that I would inadvertently block some of the airflow through the radiators by restricting the exit path of the air transitioning past the radiators and through the engine compartment. In particular, the catalytic converter probably runs extremely hot and I would want to preserve the airflow past that.
    But why steel rather than aluminum or carbon fiber, etc?
    Please post pics of yours as I might also go down that road,
  6. bisco
    52,362
    wow, steel? weight?
  7. gliderman
    gliderman Active Member
    751
    225
    There are several other good reasons it is plastic besides weight.
  8. Robert Holt
    1,313
    889
    Plastic shield: cheap, light, no corrosion, somewhat stiff but flexible under slight impacts, no oil canning sounds, easily and quickly moldable. What am I missing?
    Metal shield: depending on metal and gauge chosen a metal shield could be stiffer , have electrolytic corrosion with the chassis steel, thin gauge may oil can, denting under slight impacts, expensive, heavier, and hard to form.
    Carbon fiber shield: very stiff, brittle, electrolytic corrosion , may crack under slight impacts, very expensive, heat resistant, very light, complicated to form depending on wet layup versus autoclaving.
    Fiberglass shield : moderately stiff, no electrolysis , cracking under heavy impacts, expensive, may sag/melt/burn with high heat, medium strength, moderately hard to form.
    So I see different pros and cons with different materials. What do you all think?
  9. Mendel Leisk
    41,873
    Agree. I've avoided using the "oil change flap", taken the whole shield off about 11~12 times now. Every time I wash out the plastic fasteners in hot, soapy water, they all still work like new, ditto for the overall shield.
    I would suspect if the shield is failing it's due to protracted neglect, a service department that is loosing or breaking fasteners, and/or use the aforementioned flap till it's dangling, snagging on things. If in fact the OP's woes are due to snagging rocks/roots or whatever, he's in the wrong vehicle.
  10. trip1027
    trip1027 Member
    106
    27
    wyoming
    Well the welding shop ended up not doing it... came up with excuses.... so I went to home Depot picked up a 3'x3' sheet of aluminum diamond plate and made it into two pieces so I only pull off half to do my oil change.... so until I have time to do it for real this should work in the mean time. Took it on the interstate up to 90mph for 5 miles. Nothing fell off or came loose so I think we are good. uploadfromtaptalk1470448087960.jpg uploadfromtaptalk1470448091981.jpg
    SM-N920V ?
    Robert Holt and bisco like this.
  11. bisco
    52,362
    wow, that looks good! all the best!(y)
  12. trip1027
    trip1027 Member
    106
    27
    wyoming
    It's 0.025 in. thick so maybe last to my next oil change
    SM-N920V ?
  13. Mendel Leisk
    41,873
    About 1/32". Not bad.
  14. bisco
    52,362
    maybe you should change your oil more often.:p
    Raytheeagle likes this.
  15. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    I have been missing the oil change flap for about 4 years now with no problems at all.
  16. trip1027
    trip1027 Member
    106
    27
    wyoming
    I do my own oil changes.... and I drive around 60k miles a year so yeah damage will come with bad roads
    But he'll that gas mileage makes a world of difference in my wallet
    SM-N920V ?
  17. trip1027
    trip1027 Member
    106
    27
    wyoming
    Every 10k miles that's once a month for me buddy....
    SM-N920V ?
  18. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    My oil change cover has been missing now for over a year, probably 2. The back flap on the splash guard just flew off going 85 mph outside Kettlemen city. All fasteners were in place and I reinforced the back of the splash guard with zip ties as it seemed flimsy.
    On the fence about replacing either. The main cover is still in tack protecting and in Northern California, there is little rain, so replacement can wait awhile:).
    lar.smith42 likes this.
  19. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    If you traveled 60 k annually, wouldn't that be an oil change every other month?:confused:
  20. trip1027
    trip1027 Member
    106
    27
    wyoming
    Not every month is the same
    SM-N920V ?
