Noise in central column.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Piotrus Pan, Jul 17, 2016.
  1. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    Hi everyone!
    It's one of those crackling/vibrating sounds when driving a certain speed. It's located inside the column right between the driver and passenger.
    It stops when I push the column with a finger but it's kind of annoying keeping my finger there all the time ;-)
    Does anyone have a video or pictures of what I will find there after unscrewing those 4 screws inside that compartment? I just don't want to go blind and end up unable to put it back together.
  2. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    If someone would have the same problem:
    There are 5 screws there. 4 are under the matt inside the container and the 5th is right above the cup holder behind a plastic cover. The plastic cover is on clips so just pry it with a screwdriver on one of the sides and it comes out. All screws are 10mm.
    The thing that was crackling were lose washers. Those washers are on a hand/foot break line so when you don't use it the line is loosen and the washers can make noise. This whole plastic box resonates I guess that's why it makes it louder.
    I just took isolation tape and taped those washers together. The hand/foot break works with no problems and the noise is gone.
    Cheers!
    Rebound and bisco like this.
  3. bisco
    52,286
    well done!(y)
    Rebound likes this.
