Demister
Discussion in 'Newbie Forum' started by John Drinnan, Aug 4, 2016.
Tags:
  1. John Drinnan
    John Drinnan New Member
    New Zealand
    Hi - new Prius owner. Dumb question, Having problems with demister in wet cold weather. I want to stop windscreen fogging up without using (noisy fan) What should heater be set at - Aircon on or off?
    Burna J likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
  3. Tideland Prius
    16,634
    You want to keep the windows free without using the demister?
    A/C on.
    If you use the demister, the A/C is on regardless of whether the light on the A/C button is illuminated or not. If you want to reduce the fan speed, then press the demister button and then manually lower the fan speed.
    But yeah otherwise, in AUTO mode, just leave the A/C on. (and the temperature doesn't matter. Just set it at the temperature for you to be comfortable)
