Light bar project
Discussion in 'Gen 3 Prius Accessories and Modifications' started by trip1027, Aug 7, 2016.
  1. trip1027
    trip1027 Member
    106
    27
    wyoming
    Here is my light bar I finally put on my car. Had it on my hood before now it is up on top uploadfromtaptalk1470604960674.jpg
    SM-N920V ?
    Chubybubby and bisco like this.
    52,379
    wow! i gotta see that at night!(y)
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Let me guess, you hit something on a dark road previously, explaining the mismatched bumper cover and the light bar?
  4. huxington
    huxington New Member
    Los Angeles
    You should definitely order a grill that you can fab the light bar into. That would be neat.
  5. trip1027
    trip1027 Member
    106
    27
    wyoming
    Imma do a whole bumper and skid shield in aluminum this upcoming winter when I am at home
    SM-N920V ?
  6. connorkulesa
    connorkulesa New Member
    Placerville Ca
    Im new to priuschat but I have been building a offroad prius
    based out of placerville Ca
    Burna J and granTORRESmo like this.
  7. CharlesCather
    CharlesCather New Member
    Pensacola FL
    Connorkules, how do you have your light bar wired, did you have to run wire all the way to the 12v battery?
  8. QPilot
    QPilot New Member
    Bakersfield
    Four Touring
    I just got my 20inch led bar light and two 4 inch led bar light too. But not to sure where to put them.
  9. whenmountainsmove
    whenmountainsmove New Member
    Yacolt, WA
    same problem. I’m not sure I can use the 12v because it’s not utilized like a regular gasoline engine would use it. So I’m not sure if it would drain or not.
  10. Priipriii
    Priipriii Member
    231
    67
    You can use the 12v. The only way itll drain it is if theres a connection. But the moment you click the light bar off, the loop is closed and no connection. Battery recharges only when car is in ready mode just fyi.
  11. SnowMexicanuck
    56
    66
    Quebec, Canada
    The 12V battery is being charged when the car is running just like any other car, so a light bar won't be a problem unless you somehow forget to turn it off when you turn the car off. Which would be slightly concerning if you were driving in a state of mind where you don't notice that when getting out...
  12. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    need more lights!
