Gen 4 HVAC usage and settings?
Discussion in 'Gen 4 Prius Technical Discussion' started by Blizzard_Persona, Aug 20, 2016.
  1. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Since I bought my new 2016 a couple weeks ago I have been trying my best to keep the AC set to 74 and ECO (HVAC ECO) and always on ECO drive mode too as recommended on here....
    Thing is the last 2 weeks here have been the hottest 2 weeks of the year thus far. I have been running the AC at 72 and even down to 70 for a day or two and alternating between the ECO and Normal Hvac settings depending on how the cabin felt due to the oppressive heat and humidity. I really don't like to feel uncomfortable and I really do enjoy the AC.
    Question is, Is it better to run the AC a couple/ few degrees colder on ECO or a couple/ few degrees warmer on Normal? How will mpg's be affected on way or the other?
    This is so far a summer AC type question, but with winter a few months out the same could be asked re. the heater.
    Thank you all who reply..
    51,829
    a warmer setting should provide improved mpg's. eco only suppresses compressor operation, so achieving lower temps is more difficult.
    kithmo, RCO, WilDavis and 1 other person like this.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I have a 2009 Gen II and in summer used to run with the A/C off and the windows cracked open just a tad (especially easy with deflectors), but this summer in the fierce heat & humidity, I've been setting the A/C to AUTO, the temp to 78 (or sometimes 72) and letting the Prius's brain do its thing. I've noticed that on short runs with the A/C running the SoC indicator goes up and down, like the proverbal "Whore's Drawers", and I have a ScanGauge II which confirms that and also displays the Voltage of the Traction Battery, but on the longer runs, the SoC quickly settles down to all greens, and the voltage is around 230-240. I think running the A/C causes the MPG to take a slight hit, but heat is the big enemy of the Traction Battery, so the cooler the interior of the car, the better it is for the battery (the air-intake for the Traction Battery is inside, by the right shoulder of the rear passenger on the right-side).
    In the colder weather I block the grill (see threads passim) and usually wait for the ICE to kick in (and sometimes run until it shuts off) before moving the car. - hope this helps - Wil
    RCO, bisco and Blizzard_Persona like this.
  4. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    You probably don't care what us low-life Gen 2 owners think. :( Probably get more Gen4 owner replies in those forums.
  5. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    All Prius are awesome!!
    But yeah...
    Wow!! I sure screwed that one up!!! thought I posted the thread on the Gen 4 section.... Obviously not :(
    sorry...
    Hopefully a mod can move this thread over...:)
    I PM'd Tideland and requested that he pls relocate this thread..
    #5 Blizzard_Persona, Aug 20, 2016
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I guess I think differently. I want total comfort in the cabin when it comes to hot weather. I'm not concerned about a 1 or 2 MPG loss because I am running my AC.
    I use the AC 90% of the time, in normal mode, not "Eco." It's very nice. (I also want the cabin to be cool for the Hybrid battery.) My MPG is always a steady 60-62; I am very satisfied with that.
    Bluegrassman likes this.
  7. booke02
    booke02 Active Member
    391
    415
    Israel
    For comfort in the really hot weather, go for Normal
    kithmo and RCO like this.
  8. Coast Cruiser
    2,267
    2,571
    ...and I always have the Temp set at 65, in the summer.
    In winter, I'll bump it up to 68. :D
  9. Mendel Leisk
    41,282
    I don't use the AC much, and this is 3rd gen experience, car in Normal mode. Anyway, what I do:
    1. Set Auto and AC button on.
    2. Raise temp setting until fan speed stops racing, settles down to about half of full speed. This can mean temp set as high as 28~30C, if it's really hot
    3. As cabin temps stabilize and fan speed drops, adjust set temp downward. Typically I'll settle on 25C as final setting.
    #9 Mendel Leisk, Aug 20, 2016
    HVAC, RCO and WilDavis like this.
  10. Coast Cruiser
    2,267
    2,571
    You confused me. A bit too complicated.
    I don't use that "Auto" setting.
    My AC is already on when I start the car. The temp is always at 65. The fan speed is always on low...
    Go buy an Egg McMuffin. :)
    RCO and 'LectroFuel like this.
  11. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    So in essence only a few degrees off off what the beautiful and perfect Cali Coast weather is on any given day??? :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::whistle:
    Here it was 105 real feel temp last week with the disgusting humidity...65 on auto would mean the AC would never change from full force. Lol.
    RCO and Coast Cruiser like this.
  12. Coast Cruiser
    2,267
    2,571
    It's been near, or at 90 most every day in my area. But very low humidity. Terrible fires going on.
    Auto AC on full force: Yes, that's why I just use the manual mode. I can set my own fan speed.
    But when I did use Auto, every time I lowered the fan speed it would disconnect the Auto mode... So now I just use manual all the time.
    Blizzard_Persona likes this.
  13. Mendel Leisk
    41,282
    Assuming in regards to setting the AC at 25C, it works good at that temp, feels surprisingly cool. 24C at the lowest.
    Coast Cruiser likes this.
  14. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Celsius???
    Lol.... I haven't lived in Canada in almost 2 decades.... My metric memory has since faded.. Pls enlighten me on conversion to Farenheight...;):D
  15. Coast Cruiser
    2,267
    2,571
    People must think I'm nuts for saying I have my temp set at 65 degrees. Even in the morning. But I'm a big man, and I always feel "warm." (It's my fault for being so heavy. Not good!)
    When our "winter" comes (which means it could still be 80 on Christmas :ROFLMAO:) I hope we get some nice cold weather. I might like to actually try out the heater in my Prius.
    RCO likes this.
  16. Mendel Leisk
    41,282
    Times 9/5 plus 32, nothing to it. 24C's about 75F.
    #16 Mendel Leisk, Aug 20, 2016
  17. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I turned my A/C on in 1976, and it's barely been off since (OK, off mostly in winter) - if it's hot, the A/C is on.
    The Gen 4 AUTO mode seems to have a mind of it's own - it will sometimes turn AUTO off if I select RECIRC - then 5 mins later, it will happily allow it. Other times, if I want it to deliver air to FOOT+FACE, it will turn AUTO mode off as well and later reverse it's decision.
    There are 2 ECO Modes - if you select ECO Mode for the CAR, it will set the A/C to ECO A/C Mode. But you can also have the car in POWER or NORMAL Modes, and select ECO Mode for the A/C.
    I went for a drive last week, it was a warm, but not hot day (28 max I think), A/C between 23 & 24. I noticed that in AUTO "DriverPriority" A/C mode, + RECIRC, FOOT+FACE, sometimes it wasn't cooling enough, so turning Driver Priority OFF, it cooled much better - I flicked it between ON & OFF a few times. I'll work it out one day.
  18. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I thought the ECO air setting reduced the air out of the passenger and rear vents. Fine with me, assuming it's blowing on me. I do notice the temperature differential from the actual to the desired will increase the fan speed and open up the passenger vents. My normal temp setting is 65. It does very little to the fuel mileage. Actually I never looked at it, nor do I care when it's 100 at 95% humidity. That said when it's a nice day the windows and the sun roof are open.
    RCO likes this.
  19. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    I keep mine on 68 Auto, ECO, Driver Priority and that's really as cold as i ever want it. Sometimes ill even bump it to 70 because its too cold. With 68 i still get out of this world MPG so i'm happy with it
    RCO likes this.
  20. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    I think either method would have almost exactly the same effect on mpg, because you are adjusting both modes until they are doing the same thing as each other. I suggest you use the method that is most comfortable and convenient for you.
    RCO and Blizzard_Persona like this.
