05 Prius Bearing/Pulley Noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mil-town Prius, Aug 21, 2016.
  1. Mil-town Prius
    Mil-town Prius Junior Member
    milwaukee
    Hey Guys,
    I just spend 2 hours searching no one ever had this ?
    Sounds like a bearing noise, Idler pulley or would Water Pump make that noise?
    I certainly hope its not a Crank Bearing ?
    Thanks in advance!
  2. JC91006
    JC91006 Senior Member
    16,697
    8,528
    There's a water pump pulley. If the water pump is over 100k miles, then it's probably time to replace it
  3. Mil-town Prius
    milwaukee
    So you replace that alone, or whole water pump ?
  4. JC91006
    16,697
    8,528
    I would replace everything, pump, pulley, belt
  5. Mil-town Prius
    milwaukee
    Pump was replaced with recall, thats why I am confused. Perhaps Idler pulley ?
  6. JC91006
    16,697
    8,528
    How long ago was it replaced?
  7. JC91006
    16,697
    8,528
    Recall was on the electric pump
  8. Mil-town Prius
    milwaukee
    It was a couple years ago, so there is an electric pump and mechanical water pump ?
  9. JC91006
    16,697
    8,528
    Yes 2 pumps. 1 for the regular motor, 1 for the electric motor.
  10. Mil-town Prius
    milwaukee
    no one thinks it could be bearing noise from Idler pulley ? How would you check, remove belt and turn by hand ?
  11. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Sometimes a length of heater hose held up to the ear can help narrow down a noise location. Or a mechanic's stethoscope if you want to get fancy.
  12. ChapmanF
    17,548
    Mechanic's stethoscopes are really inexpensive and work wonders. If you had one, you'd know your noise source in a jiffy.
    It could very well be your idler pulley ... that was the only thing starting to get noisy on my old Gen 1 by 238,000.
    -Chap
  13. AzWxGuy
    AzWxGuy Weather Guy
    1,040
    524
    Tucson, AZ
    2021 Prius
    I would agree that the idler pulley bearing should be checked first. Check the tightness of the belt first because that can make noise also. Does it make the noise when the engine isn't running? That would point to the electrics, of which there are three; coolant storage tank pump, inverter coolant circuit, and a backup ICE electric pump to cycle the coolant in cold weather when the ICE is off and cabin heat is requested. Does it make noise while the engine is idling? If so, a careful spritz of water from a hose on the bearing might temporarily quiet it and indicate the source of the noise. Could be the mechanical water pump bearing, especially if you see dried pink antifreeze crust on the pump housing and a curious pink crust line drawn across engine compartment components and the hood soundproofing in line with the pulley radius.
  14. JC91006
    16,697
    8,528
    If you're going to take the trouble to remove it, you should just replace it. All those parts combined are fairly cheap if you DIY
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Open the hood and put your head down in there and listen. Sometimes helps to roll up long piece of paper into a tube and use it to listen.
    In order to get the engine to run continuously go to Youtube and look up PRIUS INSPECTION MODE. Few button pushes and the engine will run continuously for testing and listening.
    Have you ever run the engine so low on oil it threw an alarm on the dashboard?
  16. ChapmanF
    17,548
    A mechanic's stethoscope is, like, six dollars at walmart, and so much more definitive than rubber hoses, paper towel rolls, etc., it's like night and day.
    Mine lives in the car at all times....
    -Chap
  17. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Agreed but in this instance cardboard tube would probably suffice.
  18. Mil-town Prius
    milwaukee
    Thanks for all the help guys! It was the water pump! Replaced that and Belt about $50 total from advanced Auto with some coupon codes,
    then I lost about a gallon of coolant I think, so i ran to Walmart got the Asian Zerex Valvoline(?) and I think I am good to go!
  19. ChapmanF
    17,548
    That's probably ok. You can't go wrong using Toyota SLLC.
    If you haven't, be sure to look up the procedure for air bleeding the system ... pockets of air trapped in the cooling system won't be good for the engine long-term.
    -Chap
  20. andrewclaus
    993
    326
    Golden, CO
    Ditto all this. If you're not familiar with bleeding air from the Prius engine, definitely do this. It's pretty tricky and very important. Toyota mechanics even don't get it right sometimes. Two tricks you need to learn--run the CHRS pump manually and use the upper radiator bleed valve.
