Shoes
Discussion in 'Gen 2 Prius Main Forum' started by kfarad, Jun 1, 2006.
  1. kfarad
    kfarad Junior Member
    56
    Palo Alto, CA
    There's a rumor going around the internet that driving without shoes can significantly increase your MPG...
    I havn't seen any threads devoted to this issue around here...
    Is there something to this? :huh:
  2. Manksgloob
    Manksgloob Member
    243
    Maybe it allows you to "feel" the pedals better. With no 3/4" pseudo-rubber barrier between you and the pedal, you could become more sensitive to your car.
    You would then be able to make more subtle adjustments.
    Just a guess.
  3. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    <div class='quotetop'>QUOTE(beeri @ Jun 1 2006, 01:11 AM) [snapback]263877[/snapback]</div>
    While not permitted in a few states... It might be possible. In the past, I've driven sports cars (clutch) better with out shoes. When you are not wearing shoes, you can feel slight changes in the return spring on the throttle. However, since the Prius is by wire... it might not be the same.
    Give it a try and let us know how it turns out?
  4. ErikU
    ErikU New Member
    97
    DFW area
    I'm a bartender at a restaurant and don't wear my shoes after getting off at night because of all the grease and grime on the shoes. I've only had the car about a week and have noticed that you definitely have more ability to get in the "sweet spot" where you get better mpg.
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Generally, driving barefoot is perfectly permissible. See
    www.barefooters.org for live quotes from state officials on the
    subject. You may also be surprised to learn that most states
    have *no* supposed "health regulations" concerning food establishments.
    _H*
  6. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    Well, in that direction, take off all your clothes.
    Less weight, and you would then increase your MPG.
    IF, however, this is a serious discussion on weather you can take your shoes off, and feel the pedal better, thus increasing your mileage, I can't see how that is possible with this car. As stated, it has a wire.
  7. Tideland Prius
    16,597
    no idea. I'm okay with shoes and feathering. Although I do have problems with the heavier basketball type shoes. Runners are ok.
  8. parrot_lady
    parrot_lady Member
    350
    Chicago Burbs
    <div class='quotetop'>QUOTE(Manksgloob @ Jun 1 2006, 02:18 AM) [snapback]263881[/snapback]</div>
    actually my mom used to yell at me for driving shoeless. There are NO laws against it anywhere, but they will reccomend that you wear shoes while driving. Couple of barefoot communities have those rules posted where they wrote/called state police.
    I perfer shoeless driving, especially with long road trips.
  9. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I know it's summer when I have to wash my feet before I go to bed. I've driven in bare feet for years, weather permitting. I keep a pair of sandals handy so I don't burn anything when I get out. On most cars, I get better 'road feel', though I'm not sure that applies to the Prius. It's much cooler and more comfortable, which is enough by itself. I don't wear pajamas, either, but you don't need to know that. :blink:
  10. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(TJandGENESIS @ Jun 1 2006, 02:13 AM) [snapback]263905[/snapback]</div>
    In the 90's it was illegle to drive without shoes, not like they would pull you over and check.. However if they pulled you over for another infraction and saw you wernt wearing any it was another ticket..
