Your Opinion: Prius TWO or Prius TWO Eco?
Discussion in 'Gen 4 Prius Main Forum' started by fsu23phd, Jan 8, 2016.
  1. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    We did buy a 2015. There were several things we didn't like about the 2016 including the lack of a spare tire which is a big issue for me.
    Right. For those who don't care about having a spare fine. For those, like me, who won't buy a car without one at least make it an option and make sure the space is still designed into the car for the spare and tools.
    #41 jdonalds, Aug 21, 2016
    Mendel Leisk and frodoz737 like this.
  2. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    They make the two/three/and three touring with a spare...FYI.
    Coast Cruiser likes this.
  3. jdonalds
    541
    225
    Right. But I'm talking about the other models that don't come with a spare. At least Toyota could leave the space for the spare, still claim the mpg increase, and give us a $200-300 option to buy the spare and tools.
  4. bisco
    52,103
    i think they did.
  5. Tideland Prius
    16,571
    You could if you want to. @kithmo did that on his UK spec Prius. He swapped out the foam pieces and added a spare tire.
  6. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    You only need your car towed if the tire is shredded. Most flats I've had are the leak type that hold air long enough to get somewhere. Keep in mind the eco has a 12v inflator.
    I would get the eco. If the spare is a must have then take it up a notch to the three. You won't regret that either.
    goinskiing and krmcg like this.
  7. priusbee
    priusbee Member
    125
    SF Bay Area
    I had a few flats and I was traveling more than 100 miles from home, I would have been stranded if I did not have a spare.
    Do you think a spare tire is needed? Definitely!
    RCO and alanclarkeau like this.
  8. gabacho
    gabacho Junior Member
    memphis
    RCO likes this.
  9. gabacho
    memphis
    I purchased a new Eco two months ago. I haven't had a flat tire on ANY car since I don't remember when. Nevertheless I plan to buy a used spare to leave at home, just in case. Also, I plan to take the spare with me if I go on any long trips. As for the rear window wiper, I can't see a use for it. BTW, after 2500 miles I am getting well over 60 mpg for mostly in town interstate driving at 60 mph or below.
    RCO likes this.
  10. Prodigyplace
    12,596
    11,792
    Central Virginia
    The 2017 Prius has the spare along with many safety features that were unavailable on the 2016 Two and Eco. That helped me choose a 2017 Two.
    RCO likes this.
