Cruise control fail
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Kedavis, Aug 4, 2016.
  1. Kedavis
    Kedavis Member
    San Diego, California
    2019 Prius Prime
    I have had my 2016 Prius 4 Touring with PCP for almost four weeks. I have successfully used dynamic cruise control every day.
    A couple days ago I tuned on cruise control, which was acknowledged by the warning "use only on expressways." Then when I tried to set a speed nothing happened. No acknowledgement, and when I took my foot off the accelerator pedal, the car slowed down even though there was no traffic in front of me. I tried to set it several times and also turned cruise control on and off a few times.
    The next day (yesterday) cruise control worked normally.
    Should I be concerned?
    ETP likes this.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    i wouldn't worry, sounds like it might be operator error, I screwed up one time when I first got my Prius, got rattled and couldn't get the damn thing started for quite a while, after I calmed down it worked fine. Good luck.
    ETP, Kedavis and krmcg like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I got a bit frustrated with mine initially, as I was driving through roadworks with a 40km/hr speed limit - which in my last 3 cars, I'd set C/C to keep to 40 - but the Prius wouldn't set. Once the speed went up after the roadworks, it worked normally - I discovered that it won't set as low as 40 - and that you have to be doing about 50 to get it to set, but then you can reduce the speed, but not down to 40.
    ETP and Kedavis like this.
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Earlier than gen 4, you can't set CC in B.
  5. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    Still true for the 2016s
    ETP likes this.
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    OP probably shifted it in B and forgot about it.
    ETP likes this.
  7. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Every once in a while, I think I turned it on and set. And see on the screen a picture of the cruise stick with arrows how to set. I have been thinking I may be doing it to quickly. That is pushing in the button to turn it on and then quickly pulling the stick down to set. I never noticed this in the gen 2 I had. But I use the dynamic cruise control so much more now.
    ETP and alanclarkeau like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    As Alan says above, you have to be travelling at 40 km/h, which equates to 25 mph, or more to set it.
    ETP likes this.
  9. bisco
    51,529
    i'm guessing the o/p is not concerned.
    ETP likes this.
  10. raspy
    raspy Senior Member
    438
    699
    London, UK
    Actually, not quite true, according to the manual.
    "Dynamic radar cruise control with full-speed range can be set when
    ●The shift position is in D.
    ●Vehicle speed is above approximately 50 km/h (30 mph).
    However, when a preceding vehicle is detected, the dynamic radar cruise
    control with full-speed range can be set even if the vehicle speed is at or
    below approximately 50 km/h (30 mph)."
  11. alanclarkeau
    7,045
    7,592
    True - since I wrote that, I've discovered that. Only thing is, if that vehicle "disappears" at a lower speed (which I haven't quite worked out what), it seems to disengage the DRCC with an indication that there is no vehicle to follow anymore (not sure of the precise wording). It's an experiment in progress.
    ETP likes this.
  12. booke02
    booke02 Active Member
    391
    415
    Israel
    Concerned - no. But I would take it to dealer and let him sort it out. (Even if it is operator error, it's the dealer's problem)
  13. ETP
    2,802
    1,170
    Auburdale FL
    Keep us posted. I am sure it was not user error. But you never know about these things. Seems that happened to me once but could not duplicate. Might have been it timed out. Do these time out after a period of time?
    Willie Wonka, " you can never be completely sure about anything you are not completely sure about".
  14. Kedavis
    Kedavis Member
    2019 Prius Prime
    I haven't been monitoring this thread because after reading the initial replies, I decided it was probably operator error. It only happened one time (my cruise control failing to set after turning it on) and has not happened since.
    More than once I have discovered that I have been driving with the transmission in "B" without realizing. I will shift to "B" to slow down, and forget to shift back to "D."
    It could have been that, or sun spots, or a hallucination, or an alternate reality.
    If it happens again I'll mention it to the dealer.
    ETP likes this.
  15. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I did it often enough I documented my error on PriusChat. You are by no means the only one.
    Coming from 7 manual transmission cars in my past, it took a while before I would quit shifting at traffic lights.
    ETP likes this.
  16. ETP
    2,802
    1,170
    Auburdale FL
    No way you made a mistake. My world is falling.:LOL:
    Kedavis likes this.
  17. Zteve
    Zteve Junior Member
    2018 Prius
    Mine's a 2018 and it's always acted that way. Sometimes it works and sometimes it doesn't. That's typical random behavior for faulty software, what's called "buggy," which means no knows what the problem is so no one can fix it.
