Only Mobil 1 For My Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusgto, Aug 19, 2016.
  1. ETP
    2,802
    1,170
    Auburdale FL
    Tell them you want to taste test it first.
    Tell them Rizzo the rat sent you.
    Coast Cruiser likes this.
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Never been to this dealer before. They better have some fresh donuts! :LOL:
    ETP likes this.
  3. ETP
    2,802
    1,170
    Auburdale FL
    Taking your squeeze to Disneyland?
  4. Coast Cruiser
    2,267
    2,571
    No, we actually escaped from Disneyland.
    orenji and ETP like this.
  5. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    I plan to err on the side of over doing transmission oil changes as well. Will have it changed with the first oil change at 5000 miles, then again at 25,000 or so. Maybe go to 100K before changing again. Someone told me once our dealer charges about $80 for this.
  6. jaglio16
    jaglio16 Junior Member
    North Bellmore, New York
    My dealer wants $300 for the trans fluid change.
    iPhone ?
  7. jdenenberg
    jdenenberg EE Professor
    3,937
    1,934
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My CT Dealer charges $100.
    JeffD
  8. RoadNoise
    136
    187
    Huntsville, AL
    Two Eco
    Well, my source could have been wrong. Might be better to rent a lift bay for an hour?. Would have to buy a torque ratchet and a hand pump along with the fluid and washers but it doesn't look too complicated. Surely all that would be less than $300 plus the peace of mind it was done right. Second change would cost much less!
  9. RoadNoise
    136
    187
    Huntsville, AL
    Two Eco
    I would actually pay as much as $120 to avoid having to do it myself. I should call them.
  10. jaglio16
    I wish. Everything is expensive in NY.
    iPhone ?
  11. Mendel Leisk
    40,979
    A funnel and 3' of hose is simple and effective, just run it down through engine bay, let gravity do the work. You want to use it just with ATF-WS. Best to have an assistant pouring, while you monitor below.
    The dealership quoting $300 shouldn't be left alone with the car, they haven't a clue as to what's involved.
  12. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    Once you safely get the car up high enough and reasonably level, and get the plastic unpanel off, changing the transmission lubricant is easy, practically exactly the same procedure as changing oil in a manual tranmission. "Flushing" it is nonsense.
  13. priusgto
    priusgto Active Member
    194
    229
    Northern Arizona
    I plan on doing the first fluid change at 20K.
    Did the 05s first fluid change at 70K and it was getting ugly but the second one at 140K looked much better than that first one.
  14. Mendel Leisk
    40,979
    I did a very early transaxle fluid change on our 2010, around 15,000 kilometers. It was already very dark. Next one, around 40,000, the fluid looked near-new.
  15. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    Not surprising. If you ever look at an engine or transmission rebuild video or procedure, you'll see that heavy grease is applied to all of the bearing mating surfaces. It is probably this grease which mixes with the WS transmission fluid and darkens it. There's no benefit to keeping the grease mixed with the transmission fluid -- it's been washed out of the bearing or mating surface, so it's no longer doing that job. If I were doing a change on a new Prius transaxle, I'd replace the drain plug with a magnetized plug. Apparently, they will attract metal bits and you don't want metal particles floating around your engine or transmission.
    RCO likes this.
  16. Mendel Leisk
    40,979
    Yeah a magnetic drain bolt would be good.
    RCO likes this.
  17. RoadNoise
    136
    187
    Huntsville, AL
    Two Eco
    Called my local Toyota dealer to schedule my 5000 mile service and got quote for changing the transmission fluid. $175. Called another nearby dealer and they want $190. Forget that, I'm renting a service bay and doing it myself. At least I'll know it was done correctly. I've changed my own engine oil for too many years to pay that king's ransom.
    Now that I think about it, it was Bob Wilson who told me the local guys charge ~$80 for this service. Maybe I could guilt him into helping me? Bob, are you there? ;)
  18. bisco
    51,529
  19. Mendel Leisk
    40,979
    @Tideland Prius I believe got his done by Toyota Dealership for $80 (Can). I think part of the problem is they might be clueless as to what it entails, which is not a good sign. Really, 4 liters or quarts of Toyota ATF WS and 2 replacement washers is the supplies:
    You should decent wrenches, a torque wrench, dedicated funnel with 3' hose extension, 10mm allen key socket. Drain, fill with the car level till it starts flowing back out.
    Addendum: I kinda forgot where I was, the fourth gen forum. Still, some of the above, and the (3rd gen) attachment should still be applicable.
    #119 Mendel Leisk, Nov 4, 2016
  20. bisco
    51,529
    through in a bob wilson, (shaken, not stirred) and you have the ingredients for success.(y)
