I'm the guy who sprayed Scotchgard and ruined my plastic
Discussion in 'Prius c Accessories and Modifications' started by priusmatty, Aug 25, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    So, I sprayed Scotchgard on my Prius C seats, but some overspray made permanent marks on some plastic. First, it got the plastic around the gearshift, and also the rear passenger door. Well, turns out a new rear passenger door interior panel will cost $450. Too much for me now. But at my 5,000 mile service, I am going to get the gearshift plastic replaces. I assume around $100. Listen carefully: if you use Scotchgard, do NOT get it on any of the plastic! Something in it destroys plastic!
    LnG and michael.sfo like this.
  2. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I'm sorry to hear about your scotch guard misfortunes :(
    Thanks for the heads up though.
  3. Mendel Leisk
    41,928
    That too bad. Contact ScotchGuard?
  4. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    I contacted Scotchgard, and all I got was, "Please follow your car manufacturer's suggestions for cleaning it off." lol I found that Armor All covers it up pretty well, but you know, I still know it is there. So, I will have to, one-by-one, replace what I ruined.
  5. Hyper Hybrid
    Hyper Hybrid New Member
    22
    Gig Harbor, WA
    Thanks for the heads up. Good to know.
  6. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    Scrubbing bubbles will take it off and won't harm the plastic.
  7. renegade_wolf
    renegade_wolf New Member
    Trinidad
    2018 Aqua
    Wish I found this earlier.
    Just ruined my door panel on a three week old car I was trying to protect from staining as the rains started this month.
    Stay away from the rubbing alcohol removal that you come across when googling how to remove it just makes things worse by removing the dye from the panel.
    Never Again.
    Meguires ultimate protectant hides it but at certain angles you can tell.
  8. frenzee
    frenzee Member
    95
    73
    Costa Mesa, CA
    Are you talking about the one-piece plastic panel that goes all the way from the window sill to the bottom? If so, that thing is made of a special plastic that is naturally stain and dirt repellent, so I don't think you need any sort of protectant. On my 2013 with 110k it looks brand new, and all I do is occasionally wipe it down while I'm doing the windows (I use Invisible Glass), although it never really gets dirty, except sometimes I see that neon-yellow insect poop stuff o_O I would completely agree with NOT using rubbing alcohol on any plastic parts though. Alcohol dissolves many if not most plastics.
    Did you try using Goof Off or a citrus-based cleaner?
