Checking tire pressure.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by priusmatty, Aug 27, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    How often do you check your tire pressure? My stocks are Bridgestone Turanza 2 types. I check once every couple of weeks, but should I check more often?
  2. ETC(SS)
    7,130
    Every coupla weeks is probably just fine especially if you find that the values aren't changing much.
    I check oil/air and glance at the fluid levels about every other tank.
    You're probably checking your air pressures more often than 99-percent of your fellow drivers.... ;)
  3. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Ok good haha. I drive for Uber, so I am a little more concerned about it, but it is usually ok, or maybe a tiny bit under what I Want it to be.
  4. ETC(SS)
    7,130
    Just saw your location.
    Hope you're high and dry there.
    Good Luck with the Ubering!!
    Merkey likes this.
  5. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Thanks! Managed to avoid the floods.
  6. Mendel Leisk
    41,243
    Check a bit more frequently in fall when temperatures are dropping.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I second the advice to be diligent when you are entering seasonal temperature changes.
    And I always check in the morning before driving.
  8. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Good point. It is most accurate on cold tires.
  9. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I check mine monthly. Although seasonal changes do affect the tire pressures, I keep my tires about 3psi over the recommended figure and I've never experienced more than about 1 to 1.5psi drop or rise month-to-month.
    If you're an Uber driver then I commend you for taking such a responsible attitude to the condition of your vehicle. But I'm rather of the opinion that the TPMS system combined with a monthly check and a daily morning walk-around of the vehicle will keep you out of any serious trouble. IMHO the benefit of actual tire pressure checks over and above that are more likely to be better tread wear and fuel economy than preventing a safety issue.
  10. sethr
    sethr Junior Member
    Fairfax, VA
    2016 Prius c
    I have always checked monthly, plus every time the average temperature changes by 10 degrees, (which equals 1 p.s.i.) whichever comes first. I also made it a habit to check for a few days after hitting a major pothole (we have lots in my area), in case the wheel or tire got damaged and caused a slow leak. Only happened once, but once is enough.
  11. Mendel Leisk
    41,243
    Yeah that's a good one, so easy to do.
