Prius destroyed by lightning on hwy
Discussion in 'Gen 4 Prius Main Forum' started by c-man, Aug 31, 2016.
  1. c-man
    c-man ordered my c
    ----Canada----
    51,892
    shocking!:eek:
  3. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I actually was over at a friend of a friends house and their car got hit by lightening in Tampa, FL (prior lightning capital of the world). Just made a 2500 mile trip in several states with their brand new GMC yukon and when driving down the road at highway speeds during a storm, the lightning bang happened and ended up frying 17 different computer systems. They were able to steer the car to a stop on the shoulder as they lost all power. They were ok, no ill effects, but their antenna was melted on top of the car. They couldn't even unlock the doors and had to call a wrecker. They decided to trade it in and take the hit in fear of other unfound issues after the car was struck. Hope this never happens to me! I would be all shook up as well.
  4. fotomoto
    fotomoto Senior Member
    5,635
    3,812
    So. Texas
    Sweet bike C-man.
    c-man likes this.
  5. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I am actually surprised that a car can be hit by a lighting bolt in the first place.
    Cars are on rubber wheels and are therefore very well insulated from the ground. So a lighting will form with something else in the vicinity that offers far less electrical resistance.
    And even if you are hit, you need a pointy metal thing to enable that. The new Prius doesn't have any pointy metal things to attract lighting. And the sharkfin antenna is round and made of plastic (otherwise the antennas inside would not be able to transmit).
    So I wonder how the Prius mentioned above could be struck and where exactly on the chassis.
    And *if* you are struck, the car is a Faraday cage, so I don't get it how the electronics in it can get fried - likely via the "ground" connection.
    Never heard of cars struck by lighting here in EU. Well, at least they never talked about it on the news. And we do get lighting storms...
    alanclarkeau likes this.
  6. robsnyder20
    378
    302
    SW Florida USA
    Good point Pakitt, I can tell you in Florida, cars do get hit and sometimes, even blow out the tires, at least from what I saw on the news channels. Lightning can and will hit anything, and is attracted to metal. Anything higher than ground level is a target. I used to work for a cable company and even though lightning is supposed to take the shortest path, it can go thru electrical lines, telephone lines, and cable lines. I imagine thats how it blew out the car computers. Your car chasis is connected to the battery, so therefore everything electrical would have been jolted potentially with a lot of voltage.
    alanclarkeau and pakitt like this.
  7. pakitt
    2,173
    1,313
    Colorado
    Well, at least in any case better to be inside a car when a lighting strucks. Because even if it destroys the electronics it doesn't kill you (unless you have an accident, that is), due to the Faraday cage effect, you are safe and sound inside it.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    True - I'd rather be IN the car than near it.
    I'd wonder if the Faraday Cage effect would only totally apply if the car was totally enclosed, but the Prius isn't strictly an enclosure - the glass (assuming windows were closed) and sunroof if equipped could potentially provide disruptions to the Faraday Cage effect.
    Lightning is strange, though - it will run horizontally, or zig-zag. I had a close shave 6yrs ago, I was walking on the sidewalk in front of my house with a storm threatening on the horizon, only partial cloud cover, and felt my hair stand on end, simultaneously heard a zzzzzzz along the power lines above, then 30-40 metres away a deafening BANG as a lightning bolt hit a tree behind my home.
    We had a power switchboard at work mounted about a metre from the ground - the lightning thought it was quicker to go via the switchboard (parts of which landed 60 feet away) than direct to earth. Soon after, a tree was hit (which exploded spectacularly), which I would have thought would be higher resistance than direct to earth.
    KrPtNk likes this.
  9. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I doubt the tires are a factor in a lightning strike. The bolt basically has a choice, it can either go through about 4 feet of air, or go through the highly conductive car body and then through the 6 inches or so of air under the car.
    Years ago the house I lived in was struck by lightning. Two outlets in my bedroom had their plastic covers blown off. On one, the wallpaper was blown off the wall between the outlet and the radiator connected to the furnace. The other outlet was where my clock radio was plugged in. The plug was scorched, and the wire had a short section vaporized where it hung against the radiator. After fixing the cord, the clock still worked. The TV downstairs still worked, but the colors were wrong on one corner of the screen (magnetized by the strike?). The only confirmed casualty was the phone and answering machine on the far side of the house.
  10. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    if you feel your hair stand on end, quickly squat down making as small a ball as possible and get on the balls of your feet instead of flat feet...
    iPhone ?
    alanclarkeau and Zythryn like this.
  11. alanclarkeau
    7,045
    7,592
    Thanks, I'll remember that if it happens again - hopefully, I won't have that experience again though - but, I was obviously running one minute too late.
  12. c-man
    c-man ordered my c
    ----Canada----
    Yeah I always thought a car was a safe place to be, as well. But it happens. A guy from my town was struck on his motorcycle the other day, news said he "woke up 2 hours later", managed to ride home (an hour from Niagara!) and then his wife called EMS. Crazy.
    I was wondering if the Prius battery pack could "attract" lightning somehow. I don't think I'd want to be sitting on it in the back seat. But after a bazillion miles of testing, it seems unlikely. (?)
  13. pakitt
    2,173
    1,313
    Colorado
    The Prius battery cannot attract anything more than any other part in the car. It is inside a metal case. Which is a Faraday cage in itself and it is inside the car chassis, another Faraday cage. No way.
    RCO and alanclarkeau like this.
  14. bisco
    51,892
    it attracts me.:love: and my wife calls me lightning.:p
    RCO likes this.
  15. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Couple things, while the car's body will protect you from lightning it doesn't mean the car's computer and electronics are protected. Computers and any transistorized electronics are sensitive to electrical impulses. Even a nearby lightning bolt can induct enough voltage to cause damage to electronics nearby. The "induction" is the problem, this is what is fries the computers in cars when they're struck by lightning.
    Cars can and do get struck by lightning, sometimes nothing happens, other times the car is totaled. Have to keep in mind we're dealing with millions and million of volts with a payload in the millions of amperes all which occurs in a fraction of a second. So the effects are often all across the board.
    RCO, alanclarkeau and pakitt like this.
  16. fuzzy1
    10,431
    If the spark can jump across the 10,000+ feet of air insulation above, then the additional 4 inches of air below is little impediment.
    Few natural lightning targets are metal. Many aren't even pointy, e.g. the ground and lake surfaces. Lightning can even snake its way around pointy treetops and hit ground targets very close to the tree base.
    Even when metal aircraft are hit, it can be on smooth rounded portions of the wing or fuselage, not necessarily on pointy protrusions.
    That cage is not a superconductor, it has non-zero electrical resistance. When you hit an 0.1 ohm resistance with 10,000 amps, the resulting end-to-end voltages across the ground loops are still high enough to fry much of the car's electronics. Throw in the inductance too, even a superconducting chassis can have enough impedance for the sudden spark fry that stuff. Then add in the mutual inductance, i.e. transformer action, nearby items are also toasted.
    It happens frequently here in the U.S. It isn't news unless something catastrophic happens, or someone gets video of the actual strike.
    More important than the balls of your feet: keep your feet close together. Ground current from a nearby strike will likely produce a voltage gradient between your feet. The more widely spaced your feet, the higher the voltage. This is part of the reason cattle are more susceptible to nearby strikes than are humans.
    Hundreds of reindeer killed by lightning in Norway | IceNews - Daily News
    No more than an inert block of metal of the same size and shape.
    #16 fuzzy1, Sep 1, 2016
    RCO, alanclarkeau, kithmo and 2 others like this.
  17. pakitt
    2,173
    1,313
    Colorado
    I think I would be thrown out at a physics/electronics exam....
    Thanks for all the clarifications!
  18. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I would think the burst of EMF alone, generated by a lightning bolt within a few feet, would be enough to knock out most electronics.
    RCO likes this.
  19. alanclarkeau
    7,045
    7,592
    Electronics using valves was in it's infancy - and out of scope for study - when I studied physics at school.
    BUT - I'm cool with Flux Capacitors when they arrive. Though I wonder how they might affect nearby cars.
    DonDNH, RCO, pakitt and 1 other person like this.
  20. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    God 1
    Prius 0
    RCO likes this.
