key battery low
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Loudal, Jun 20, 2016.
  1. Loudal
    Loudal New Member
    Hollywood, Fl
    A warning light has come on stating" Key battery low". How do I fix this? Thanx.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    Change the battery in the key fob
    kenoarto, bisco and Mendel Leisk like this.
  3. bisco
    52,282
    welcome to priuschat! instructions in your owners manual, or the dealer will do it for you for a 'small' fee. all the best!(y)
  4. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    It's very easy to change. Take your real key out and on the bottom you will see a spot to insert the tip of the key just twist and your key fob will come apart. ( This is for smart keys ) If you don't have a smart key then I am not sure.
    #4 TC400, Jun 26, 2016
  5. bisco
    52,282
    if you can't take the key how, and kinser the tip of the key, pm me.:p
    #5 bisco, Jun 26, 2016
    xliderider likes this.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    @TC400, turn off the Autocorrect, or put down the alcohol lol. ;)
    TC400 and bisco like this.
  7. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    You can use your spare key until that bad boy goes bad and then change the battery on both of them
  8. dame94
    dame94 Junior Member
    32
    Brentwoodish, California lol
    2018 Prius Prime
    Don't worry, I got this warning on my LS460, just change the key fob battery (I think I went on Amazon and bought 10 batteries for $11.00 )
  9. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    lol whoops. sometimes it's both
    bisco and xliderider like this.
  10. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    The battery in the non smart keys is only for the remote for the door locks. If you can live without the remote lock/unlock ability then the key's battery isn't actually needed to start and run the car. The anti-theft immobilizer reads the electronic code from the key's passive transponder chip - it's powered by the electric field put out by the reader next to the key slot on the steering column. It works much like the passively-powered smart chips in "pay wave" credit cards.
    TC400 likes this.
  11. cutter44
    cutter44 Member
    213
    MA
    I just got this same warning. Easy enough to change battery, but I am curious. Does anyone know (from experience) whether this warning means the battery is low and will be dead in a couple of months or more like a couple of days?
  12. bisco
    52,282
    it probably varies like any battery, but keep in mind you can still start the car.
  13. cutter44
    cutter44 Member
    213
    MA
    Oh yeah, I keep forgetting about that as I've never tried it. I'm assuming if it happens to die, it's not going to need to be re-programmed, will it?
  14. bisco
    52,282
    nope, just put in a new battery, and you're good to go. do you have two fobs?
  15. cutter44
    cutter44 Member
    213
    MA
    Yeah, I have two. I was going to use the other for a while until it starts giving me the warning. :)
  16. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I dealt with that message for a month or so before I changed it.
  17. Mendel Leisk
    41,824
    When you open up the fob, everything's really exposed/funky. For something that costs $200~400 to replace, they could have made the battery access a little less like open heart surgery. Also, I find a flat blade screw driver that's slightly wider than the manual key tip makes it easier to prise open.
  18. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Remove key hold remove key slider then slide bottom off remove 4 screw 04-09
  19. bisco
    52,282
    check the voltage before installing. i suppose loudal is all set.
