2006 reprogaming mileage reduction
Discussion in 'Gen 2 Prius Fuel Economy' started by flynlow, Jun 2, 2006.
  1. flynlow
    flynlow Junior Member
    24
    Anyone have their 2006 hooked up to a Toyota scantool for programming (for any reason) and notice a 3-5 mpg reduction?
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If the ECUs lose power for whatever reason, or get reinitialized,
    then the engine controller has to re-learn a bunch of parameters.
    In the meantime, it runs from the default fuel maps which are
    probably not optimized for your particular engine and driving style.
    So give it a few days and a few full thermal cycles / trips...
    _H*
  3. flynlow
    24
    This happened 800+ miles ago..
  4. badaka
    badaka New Member
    47
    Boston, MA
    Maybe yours is a slow learner. :unsure:
  5. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(badaka @ Jun 3 2006, 07:50 PM) [snapback]265322[/snapback]</div>
    He shouldn't worry. I've heard the government is about to announce a No Prius Left Behind program so remediation should be available. :p
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Does more than one person drive the car? That can confuse the leaning curve. When I had my ECU reprogrammed I had a hit for at least a tank, that is 500 mi plus.
  7. flynlow
    24
  8. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    what kind of programming did they do?
  9. flynlow
    24
    <div class='quotetop'>QUOTE(hdrygas @ Jun 3 2006, 07:17 PM) [snapback]265370[/snapback]</div>
    I noticed you have a 2004, I am seeking experiences with 2006.
