Warning when braking hard or going around sharp curve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cattail722, Sep 8, 2016.
  1. cattail722
    cattail722 cattail722
    47
    Bay Area, California
    I've been getting the triangle with ! warning when making a hard stop or going around a sharp curve. It's not consistent, but it has been happening more and more the past day or so. Over the weekend, I accidentally drove into a median and my right rear wheel was stuck in between the two curbs of the median and had to gun it to get the car out. The car has not been driving any differently, except for the warning light coming on. Anyone have any experience with this happening?
    49,694
    how is your oil level? might have a bad speed sensor on that wheel now or something else damaged.
    goldfinger and cattail722 like this.
  3. cattail722
    47
    Haven't checked the oil, but will do so tonight. Am actually wondering if this is the problem, even though it seemed to start after hitting the median. It seems to happen most when braking on a hill or going downhill or around a sharp curve. I had no idea the car would warn me if my oil was low.
    Looked up "speed sensor" and it looks like the ABS light would come on, but not necessarily the master warning light (just learned what this is called) would come on for that, if that were the issue.
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    You oil is low. How many miles on your '06?
    edthefox5 and cattail722 like this.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    +1 for low oil. That's what happens when there is too little oil and the curves/terrain dependency is a textbook case.
  6. cattail722
    47
    My car has about 112,000 miles on it. I honestly never check the oil. They've never mentioned that it was low when I take it in for service every 5,000 miles. I guess I should start doing that, as the car is 10 years old at this point.
  7. fotomoto
    5,602
    3,781
    So. Texas
    Time to start checking it when you fill up.
    cattail722 likes this.
  8. cattail722
    47
    Will do. Ten years has snuck up on me. The car still seems new and I've never (knock on wood) had a single problem with it. Better start taking better care of my baby, if I want it to last to 200,000+ miles.
  9. fotomoto
    5,602
    3,781
    So. Texas
    After a few tanks, you should be get a good handle on how much it's using between changes. You also want to check the level after the change as many places don't get it right.
  10. Mendel Leisk
    38,875
    I can see why this happens: you're there to get the oil changed. It goes up on a lift, the oil is drained, new oil is put in. There's no motivation really, for the dealership to check this. From what owners have recounted here, when the (oil pressure) warning light goes on, it's likely below the lower mark on the dipstick.
    We went to an New Toyota Owners Night, and the Service Manager was waxing eloquent, said something along the lines of: "Our goal is to ensure you never need to pop the hood". :(
  11. bisco
    49,694
    fail.
  12. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Welcome to premature engine damage and its early death.
    Start saving for an engine replacement or a replacement vehicle. You may want to price a used engine with labor, to see which way you want to go, when the time comes.
    I will bet you some money, that you will not reach 200K miles.
    1) You have engine damage, which may worsen over time.
    2) Oil consumption, which you never knew about, b/c you never checked, may get worse over time.
    3) Catalytic converter will likely have an early death, due to the likely increased oil consumption.
    Here is a picture of how low engine oil will manifest itself as the idiot light when taking a turn hard, braking hard, or accelerating hard. Oil will move around in the oil pan as the car moves. If the oil level is always maintained at the FULL mark (thus the need to regularly check the engine oil level), hard: turning, braking, accelerating, will not cause the oil pump to be exposed to air. If the engine oil level is low, hard: turning, braking, accelerating, may cause the oil pump to be exposed to air. The moving engine parts will be without lubrication for a second, two, three, or longer. Only when the oil shifts back to the pump, and the pump sucks-up oil, instead of air, will the moving engine parts be bathed in oil.
    Now, lets say the engine RPM was at 2,000, when the idiot lights appeared. 2,000RPM / 1min/60sec = 33.3 Revolutions Per Second. Say the engine oil pump was dry for only 2 seconds. 66.6 Revolutions of metal on metal were just made! Grind baby grind. Voila, engine damage.
    For future cars, check the engine oil level regularly. If the car is new, the engine may not burn any noticeable oil, for a good period of time. But at some point down the road, the engine will burn oil. Only by checking, will you know and be able to keep the engine oil level at the FULL mark, preventing metal on metal wear.
    #12 exstudent, Sep 9, 2016
  13. cattail722
    47
    Thanks for your ever-so-helpful comment.
  14. bisco
    49,694
    that was directed at post #10. however, my helpful comment was in post #2. how is your oil level, that you said were going to check last night?
  15. cattail722
    47
    Sorry, that was hard to tell, since you didn't include the quote in your response. Your comment in #2 was very helpful. Thank you.
    I tried figuring it out last night, but I'm a car idiot, as you can probably tell by the fact I've not checked my oil in 10 years. I didn't see a place where there's a dipstick. I couldn't get the cap off where the oil goes, even if I could figure out how to check it. There's a plastic container with liquid in it the color of honey, adjacent to where the oil goes in, and I thought maybe that was where I could tell there's oil? That seemed to be just below the max level. It's probably another fluid. Again, I'm a car moron. Wanted my friend to help me last night, but it was dark by the time he got there, so I've probably just completely ruined my car as ex-student so eloquently pointed out. My friend also made it clear that my choice of replacement oil is "crap", so I'll have to go get better quality oil, I guess, as well. I'm hoping it won't be dark tonight when I get home and my friend can help me.
  16. cattail722
    47
    I'm also just waiting for someone to say "read the manual". Yeah, I get it.
  17. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    We're not all car experts. Fortunately in today's world, there's YouTube. :) Look for the yellow circular grab for the dipstick and a black cap on the upper left of the engine for the fill point.
    bisco and Coast Cruiser like this.
  18. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    And for what it's worth, the fluid in the reservoir that's "the color of honey" is brake fluid, and it should be clear. That's probably never been changed. That's a dealer or hybrid specialty shop service item, since there are some Prius-specific steps to bleed the brake system. Contaminated brake fluid can cause very costly damage. Though you might want to make sure your engine is okay before spending money on the car.
  19. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Kevin posted a good practical video. :) I'm 61 years old, and I learn a lot from YouTube! Cat tail, just wait until your engine is cooled down before checking the oil. The morning is a good time. Or after work when your car has been sitting all day. And obviously, you'll want to be parked on flat ground to get an accurate reading. You got a friend, brother, co-worker that can do it for you? Proper oil level, and the right amount of air in the tires are the two "basic biggies."
    My dad always rammed into our heads... "If you don't do anything else to your car, AT LEAST check and change the oil on a regular basis!" (My sister blew up her Volkswagon motor, driving it with no oil.:LOL:)
    Cat tail, you might also want to keep a bottle of oil (or 2) in you car. (I do, and my car is brand new.) I think it says on your oil cap what "weight" your oil should be. I'm not sure for a 2006, 5W-30? Just get a couple bottles at Walmart and throw it in the trunk. Pennzoil, Mobil-1, Valvoline, about 6 bucks. Good luck with everything.
  20. exstudent
    2,214
    901
    Torrance, CA
    OP (Original Poster).
    You don't have an interest in cars , beyond driving, having to get gas, and paying someone to perform the maintenance. That's fine and nothing wrong w/ that. Someone else will appreciate earning a living off you.
    Since you live in the Bay Area you have two great independent automotive shops that specialize in Hybrids and have a superb reputation! You can go there with confidence not having to be on the defense, thinking they are going to try to screw me over.
    Also, these two shops were ahead of the dealerships in terms of hybrid knowledge and maintenance realities/issues.
    Go see Carolyn in San Fran (Luscious Garage | Hybrid Specialists)
    or Art in Berkeley (Prius & Hybrids)
    Maybe have them do your next maintenance and ask that they show you, how do I:
    *check the engine oil
    *add engine oil, and what type (regular/synthetic/blend) and grade (single weight/multi weight) of engine oil
    *check the brake fluid
    *add brake fluid (You should not have to do b/c as brake pads wear down, the fluid level drops. When the brake pads get replaced, the brake fluid level will return to normal. If the fluid is low, due to a leak somewhere, you need to add brake fluid and get thee to a mechanic to fix the leak ASAP! This is a SAFETY issue; 2ton car not being able to stop.)
    *check the engine coolant level (radiator & overflow container) & add coolant
    *check the inverter coolant level & add coolant
    *check the engine air filter
    *check the cabin air filter
    *check and add air to the tires
    Learn to do these confidently, and you will be ahead of the game moving forward.
    edthefox5 and bisco like this.
