Illuminated Door Sill install on Gen4 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by stanigu, Sep 10, 2016.
  1. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Since I haven't seen anyone document the installation of illumninated Door Sills on a Gen 4 Prius, I thought I'd snap pictures along the way to share.
    Not a difficult job--I spent about 1 hour on the driver's side just because I was proceeding with caution (and it has more obstacles). I did the passenger side in about 15 minutes.
    Part number is PT942-47160. Here's what it contains:
    Comes with all the needed hardware.
    I didn't bother with disconnecting the battery. I figured I'm not working with anything dangerous.
    First remove the scuff plates next to the door and the kick panel. Pretty simple--scuff plate is attached only at the ends, so just yank it out. Kick panel cover has a screw towards the firewall that must be removed first, but it's easily done.
    Next, remove the panel located under the driver's side dash. Two screws and one clip. Comes out easily. Disconnect the footwell light. Footwell light is where we'll tap in for juice later:
    Next, insert the "Pinch Weld Bridge" on the body--used to keep the wire from rubbing against the body and fraying down the line. It's position should be a little forward of the rear OE Harness clip.
    Here is the wire crossing the "bridge". Secure with electrical tape, then replace the weather seal.
    One thing to note: the bridge must be placed under the "soft" part of the weather seal (i.e. part that does not have a spine):
    Then route the wire along the OE wiring, above the hood release cable and behind the metal bracket you'll see. It was kind of tight, but not really bad. Here are the plug for footwell light and the door sills together, finally at last:
    Using the enclosed T-taps, connect the footwell wire with the Door sill wire. It's color coded--white and brown for the driver's side, pink and green for the passenger side. It's pretty stupid proof. Here's what it looks like after they're all connected:
    Success!
    Looks pretty neat. I replaced the interior lights with LEDs so this blue complements well.
    Passenger's side is pretty much identical, but easier since there's much less things getting in the way. The panel under the glove box is secured only with 3 clips so you won't even have screws to contend with.
    One thing that will help you is to have a good source of light. Even during the daylight hours, area behind the dash is not very well lit. LED shop light that I had helped a great deal.
    frank99, Pucieks, BLITZ XW50 and 7 others like this.
  2. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Great write-up! Have to put this on the mod list for sure.
    iPhone ?
  3. GREEN BAE
    GREEN BAE Member
    61
    49
    Winter Garden, Florida
    2024 Prius Prime
    XSE
  4. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
  5. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Damn. I was good until the $200 part
    RCO likes this.
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Very nice job. Looks great. (I'm still looking for the non-illuminated ones.) How do those attach to the door sill, two-way tape?
  7. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Yes, two-way tape. Seems to be quite secure.
  8. Tideland Prius
    16,582
    It's not too a bad price for 4 stainless steel scuff plates (of which 2 are illuminated). 12 years ago, I was looking for a set of illuminated door sills for a 2003 Corolla. It was $130 for just 2 stainless steel illuminated scuff plates.
  9. Coast Cruiser
    2,267
    2,571
    Good. I can cut the wires off, and just stick 'em on! :D
  10. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
  11. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Finding this post made me want to get these. Awesome write up!
  12. RNGeek
    RNGeek New Member
    Three Touring
    Thanks for this.
    I actually used your instructions in installing the parts to our two 2016 Prius. Very easy to follow.
  13. KnightRider2016
    KnightRider2016 New Member
    Are the connections plug and play or do we need to splice anything?
    Newbie here 2016 4 all black bought with 10 miles sitting on dealer lot in so Cal for a year.
    Thank you.
  14. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    100% plug and play.
    KnightRider2016 likes this.
  15. Kepik
    Kepik Member
    61
    37
    Bay Area, CA
    2013 Prius v wagon
    Since they're just attached via two-way tape, wondering if these could fit a Prius v... since the PIP version apparently doesn't.
  16. Prodigyplace
    12,604
    11,797
    Central Virginia
    Welcome
    Enjoy your car and the collective knowledge here.
  17. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    The pieces are precisely contoured to the 4th Gen (i.e. they're not flat), so I would think that the fit would be pretty poor (although I'm sure you could get them to light up).
    Prodigyplace and Kepik like this.
  18. Mendel Leisk
    41,701
    Do the 4th gens come with a non-illuminated threshold? No? Or just some levels? If no, is a non-illuminated threshold available?
    I mighta asked this before, can't remember the outcome.
  19. Kepik
    Kepik Member
    61
    37
    Bay Area, CA
    2013 Prius v wagon
    Ahh, got it they're not flat. bummer
  20. bobthejedi
    bobthejedi Active Member
    137
    154
    SF Bay Area
    I don't think officially, but you did ask when I posted :), it looks like they sell blank or blue stencilled Prius name, haven't seen any other colors
    Metal door sill plates | PriusChat
