Dash MPG different than Actual MPG different t
Discussion in 'Gen 3 Prius Fuel Economy' started by tearl2991, Sep 12, 2016.
  1. tearl2991
    tearl2991 New Member
    US
    I recently purchased a 2010 prius for my wife and the dash says I'm consistently getting around 42-45 mpg. The issue is when I do the actual calculation for gas mileage I'm closer to 30 to 35 mpg. Any ideas?
    52,390
    yes. how many fill ups have you had, and how are you calculating mpg?
  3. tearl2991
    US
    2 or 3 fill ups and I've been tracking my miles driven divided by fuel used. I'm confident I'm not getting what the dash is stating
  4. Fleabiscuit
    Fleabiscuit Junior Member
    42
    22
    Los Angeles
    What i normally do is fill up and then when you're filling up again, divide the current milage by how many gallons i just put in. Keep track of it for a month and then go from there.
  5. tearl2991
    US
    Sorry yes that is what I meant and have been doing
    Fleabiscuit likes this.
  6. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
    Wow, that's a big difference. I have a 2013, and The display typically runs about 2.5 mpg higher than calculated (or, about 5-6% - my data is here). From other users here on PC, it seems like 5-10% is the typical gap
    When you or your wife fill up, how many gallons do you typically add, and how many dots/pips are on the fuel gauge?
    Blizzard_Persona likes this.
  7. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    It's unfortunately typical for the dash to exaggerate mpg, but not by that much. Most report around 3-8% discrepancy, I think. Mine is consistently high by about 5%.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    To the OP, dash mpg is always optimistic.
    However, your calculated mpg is quite low.
    1) Do you have low rolling resistance tires?
    2) Are they properly inflated?
  9. fuzzy1
    10,603
    #1 and 2 address only why basic MPG may be low, not why the dash display and calculated amounts are so widely separated.
    I'd ask:
    (A) are you resetting the Trip meters at each fillup? If not, then the comparisons so far are meaningless.
    (B) are the tires of the correct OEM size?
    (C) is there any chance the fuel pump is cheating?
    Please report to us the amount of fuel pumped, miles traveled, and displayed MPG for each of the next several fillups. Please give exact meter readings, not rounded estimates from memory.
  10. Mendel Leisk
    41,901
    If I take the average of both ranges, say 43.5 and 32.5, that amounts to a 34% error. The error I've settled in on is 7.5%, with over a 100 calculated fill ups, pretty much the usual. All I can think is give it a few more tanks, if it's just variation in how you fill up, it should balance out on the next tank or two.
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Is the same pump at the gas station used? After the automatic shut off how much gas is added?
  12. tearl2991
    US
    I have been alternating resetting trip a and trip b between each fill up. The tires are OEM spec and I still need to check on tire pressure that could be an issue but yes it's possible the pump is lying but I have been to different pumps I can't imagine it being off by that much
  13. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Could be like us: mostly doing short trips around town these days...I couldn't tell you if we have as big discrepancy as I only value the hand-calc. The dash display is indicative/high.
  14. Mendel Leisk
    41,901
    I reset trip A at each fillup too, but mainly for feedback during the tank, to get rough/inaccurate feedback on mpg during the tank, and see how far I've gone. But for calculation, I use the odometer reading at each fillup, record it, subtract value at the last fillup. Invariably this matches the trip A, but you never know: the trip meters can get accidentally reset.
    Not sure if your car will work the same, but on ours at shutdown, the odometer displays, for about 30 seconds, regardless of what's displayed when the car's running.
  15. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Just adding my 2 cents here... I do average about 2.5-3 mpg difference between displayed and calculated milage, usually about 4 - 6% difference as my displayed mpg is 50-53 and calculated mpg averages about 48 plus to 50.
    xliderider and marlinsmobile like this.
  16. xliderider
    8,140
    3,277
    Honolulu, HI
    Yes, use the odometer to calculate distance traveled instead of relying on trip A meter. The trip A meter is easily reset when resetting the maintenance required light after a service is performed.
    Create an account on fuelly.com and input your odometer readings and other information from your receipts and the calculations will be done for you. You'll also get nice graphs, etc
    marlinsmobile and Mendel Leisk like this.
  17. bisco
    52,390
    go to the gen 2 forum, and answer the questions on the sticky, 'why am i not getting expected mpg'? it sounds like there is something wrong with your car, and those answers will help us narrow it down for you.
    Anthony Williams likes this.
  18. D_n_D
    D_n_D Junior Member
    42
    Auburn, CA
    2013 Prius v wagon
    I have a v and I avg 2 to 3mpg lower then the display.
    Fully calculates it easily. I always use it.
    For a 13 v3 I avg 46 mostly hwy and flat.
    Just moved and now 98% hwy. And lots of hills I'm avg 43. Working on improving it.
    If your avg is below 40 you should have it looked at.
    Depends on terrain.
    When I fill up I round to the next dollar. Ie shuts off at 19.32 I goto 20. 400+ miles with about 9 gallons.
    Galaxy?
  19. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    The readout in my 2012 Prius is about 5% high, besed on a few thousand miles of checks. The one in my 2010 MINI also is about 5% high, but the one in my 2016 Corvette is very accurate.
    I have little doubt that Toyota and BMW deliberately made the readouts indicate high, to make people think they are getting better mpg. They held it to 5% to avoid bad press and law suits.
    CR94 and Mendel Leisk like this.
  20. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    When I owned my 2 Gen 3's my lifetime variance was very close to 7% off from dash displayed mpg to calculated. As others have said I have seen as low as 4% all the way up to 9%...
    On my Gen 4 it seems to be closer to 5% off. Granted I'm only on my 3rd tank:)
    Pump up the tires for starters. Stop filling up at the first shut off click...
    Report back. (y)
