Comparing EV and HV energy costs
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Michael Levy, Aug 11, 2016.
  1. Michael Levy
    Michael Levy New Member
    Melville, NY
    2014 Prius Plug-in
    I bought a used 2014 Plug in Prius and my friend couldn't believe that electricity costs are low enough to justify EV mode.
    Based on current electricity prices, it seems to me that gas would have to be as low as $0.96/gallon to be comparable to the energy costs in EV mode.
    I would appreciate if some folks on this forum would check my work and let me know if I messed up somewhere.
    Plug in Prius estimated cost per mile in EV mode
    Plug in Prius (PiP) electric power consumption rate is 8.74 km/kWh. This is equivalent to 5.43 miles/kwh.
    Average retail electricity cost in USA is 10.42 cents/kwh. This is equivalent to 0.1042 $/kwh
    Cost per mile EV (electric vehicle) mode:
    (electricity cost $/kwh) / (power consumption miles/kwh) = (0.1042 $/kwh) / (5.43 miles/kwh) = 0.0192 $/mile
    Plug in Prius estimated cost per mile in HV mode
    Normal Prius or Plug in Prius (PiP) in HV mode gas consumption is 50 miles/gallon.
    Average USA gas price = $2.130/gallon
    Cost per mile HV (hybrid vehicle) mode:
    (gas cost $/gallon) / (gas consumption miles/gallon) = (2.13 $/g) / (50 miles/g) = 0.0426 $/mile
    HV mode costs vs EV mode costs
    The ratio of HV costs per mile to EV cost per mile is:
    (HV cost per mile) / (EV cost per mile) = (0.0426 $/mile) / (0.0192 $/mile) = 2.219
    At current average costs in the USA, energy costs per mile in HV mode are 2.2x higher than EV mode.
    How low would gas prices have to be for HV mode to be as cheap as EV mode?
    (electricity cost $/kwh) / (EV power consumption miles/kwh) = (gas cost $/gallon) / (HV gas consumption miles/gallon)
    (0.1042 $/kwh) / (5.43 miles/kwh) = (gas cost $/gallon) / (50 m/g)
    EV equivalent gas cost $/g = 50m/g * (0.1042 $/kwh) / (5.43 m/kwh) = 0.959 $/g
    Gas would have to be less than 96 cents per gallon to be equivalent to fuel costs in EV mode.
    References:
    Prius and Plug in Prius power consumption (both HV and EV) from Toyota Prius Plug-in Hybrid - Wikipedia, the free encyclopedia
    Average USA electric power costs for 2015 from U.S. average retail electricity prices 2015 | Statistic
    Average USA gas prices from AAA Gas Prices (as of 8/11/2016)
    Edits:
    Deleted the PDF because feedback was clear the assumptions were wrong.
    #1 Michael Levy, Aug 11, 2016
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Looks OK but here is a little critique.
    EIA - Electricity Data
    Your ave. electricity cost is the base ave. of utilities not of households. A utility serving a smaller population area has the same weight as a large utility say NYC area or Calif. These larger utilities are also likely to serve areas where fund, fee, charge, and tax could be equal to or greater than the base KWh charge. We pay more than $0.10 but exactly what per household is a complex calculation that I have never verifiably seen done.
    Ave. gas price also doesn't factor in the volume of gas sold at any given price.
    Need a chart or graphic calculator maybe like an aviation e6b to relate the real cost of electricity, gas, and mpg.
  3. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    Your numbers are off. Can't see where the 5.43 mi/kWh came from, but the battery has 4.4 kWh to go typically 11 miles, which is only 2.5 mi/kWh. If you consider the charging losses, it's probably less than 2 mi/kWh.
    In my area, electricity is over 20 cents/kWh, and with all the hills around here, I get less than 10 miles/charge, so I pay more to charge than to run on gas. But I do it anyway for carbon-reduction purposes, since my electricity comes from renewables and I have solar panels.
    BenM and Michael Levy like this.
  4. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Your numbers are off. You have less than 2.7 kWh of usable battery storage. Nobody in a PiP has 4.4 kWh at their disposal. At my 4.8 mi/kWh measured I'd get darn near 21 miles of EV. If you want to add the typical 15% charging loss then it's closer to 3 kWh for each charge.
    Unsupervised!
    #4 drash, Aug 12, 2016
    PriusC_Commuter and roflwaffle like this.
  5. bisco
    51,833
    another factor is speed. ev is much more efficient at low speeds, hv on the highway. these equations only work on an individual basis, not globally. mostly dependent on kWh cost, which varies much more widely than gasoline.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I multiply my electricity cost by 12 to get my per gallon equivalent gasoline cost. Below is the way I do the calculation. The givens are thusly:
    3 kWh per charge
    12.5 miles per charge
    50 miles per gallon gasoline EPA
    3 kWh / charge X electricity cost / kWh X charge / 12.5 miles X 50 miles per gallon
    Simplified it becomes
    3 X electricity cost X 50 / 12.5 per gallon
    Or
    KWh electricity cost X 12 per gallon
    My marginal cost for tier 2 electricity in the summer is currently at $0.24 per kWh. Plugging in is costing me the equivalent of $2.89 per gallon. I just filled up this morning at $2.13 per gallon. If you only get 10 miles per charge then you multiply by 15.
    My average electricity cost is significantly lower but that's how electric car companies trick you into thinking you're saving money. All my PiP charging comes from the top at marginal rates. I think it's misleading to use average electricity to calculate costs. It's like using average income tax rates to calculate how much refund you get. No one does that.
    I get $1.25 per gallon at the $0.1042 US average so I am $0.25 off from your calculation.
    PriusC_Commuter likes this.
  7. Michael Levy
    Melville, NY
    2014 Prius Plug-in
    Great feedback. Thank you all. It looks like the consensus is my formulas aren't bad, but my cost assumptions were not in line with reality.
    I got the 5.43 mi/kWh number from the Prius Plug-in Wikipedia page. It has one line that says "The electric power consumption rate is 8.74 km/kWh.", which I accepted as a good enough estimate of how far I can go on one kWh and converted it to miles. I don't know where this number came from, perhaps it is some raw number for the motor, but does not include the realities of charging and other losses.
    I understand that local driving conditions, electric rates, and driving style affect this calculation. I was just trying to get some ballpark numbers (hence the use of US averages).
    I'll try to digest all the suggestions and post an update.
  8. bisco
    51,833
    and to answer your friend honestly, you need local costs.
  9. Myrdx
    Myrdx Junior Member
    Draper, Utah
    2013 Prius Plug-in
    I recall doing this math when I got my PiP. Based on local electricity kWh rate the regular (not high octane) would have to come down to ~$1.35/gallon before it cost same to drive in EV mode only or use HV (assuming Prius gets 50mpg) mode.
    #9 Myrdx, Sep 6, 2016
  10. bisco
    51,833
    life is good in utah!(y)
    Myrdx likes this.
  11. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    The first thing I did was run the math to see cost in EV vs HV. I arrived at almost the exact same figures.
    $0.02 per mile in EV
    $0.04 per mile in HV
    Gasoline would have to be $1 / gallon to be as cheap as electrons, and this doesn't factor in the added wear on the engine itself.
    I'm in the Portland area.
  12. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I'm paying the equivalent of about $5.40 per US gallon (€1.27/litre) and 11c per kWh (€0.09 at night rates) - gas will never be the cheaper option for me :)
    mmmodem and Redpoint5 like this.
  13. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    The EPA lists shows for the PiP it takes 29 kWh/100 miles of driving, so I multiply my per kWh rate times 14.5 to equal one gallon of gas (costwise, not energywise).
    I switched to TOU rates when I bought my Leaf, which means since then I only plug in the PiP during super off-peak rate times. However, Southern California Edison raised the nighttime rates this year from $0.11/kWh to $0.13/kWh (summer) and $0.14/kWh (winter), or $1.89 (summer) and $2.03 (winter) compared to about $2.40/gallon of gas at Costco.
    With tiered electricity rates it can easily get more expensive to drive on electricity as opposed to using gas. Southern California Edison's Tier 2 costs $0.23/kWh (I don't know anyone who stays in Tier 1), which would be the equivalent of $3.34/gallon, which we haven't seen in a very long time.
  14. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Sadly, paying the true price for gas isn't going to happen anytime soon. There's so much excess capacity, we likely won't see oil going up either.
    It's an uphill battle, even with ever improving tech.
  15. Redpoint5
    1,026
    509
    Portland, OR
    This underscores how corrupt of an idea it is to allow single occupant HOV access for PiP owners. Hardly anyone buying them will plug them in, yet they will clog the HOV lanes even though they are the most efficient vehicles and consume no fuel when stopped in traffic.
    I'd install solar pronto if I lived in CA. The electric rates are silly expensive.
  16. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    Yet we are pretty cheap compared to many places in the NE.
  17. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    That's one way to look at it, and I guess the thought process could be extended to all PHEV vehicles which allow you a choice of fuel type. Why bother plugging in a BMW i3 REX (or Chevy Volt) when you can drive it with the gas engine for cheaper with the current low price of gas in California?
    Another way to look at it is that it convinced me to trade my 17mpg Mustang in for a significantly more efficient vehicle, and opened the door for me to discover the world of plug-in electric vehicles. This led me to adding a Nissan Leaf a year later to the family lineup, retiring our aging minivan that also got less than 20mpg, and putting a deposit down for a Tesla Model 3, removing my earlier interests of getting a BMW M3 or similar performance inefficient vehicle. The HOV Stickers program helps change consumer preferences towards a more efficient fleet, which outweighs the minor bump in HOV lane usage (roughly 5% of HOV users during peak hour are HOV Sticker users, as compared to numbers as high as 40% of carpool lane "cheaters").
    And I don't mean to throw solar under the bus, but in my experience it's hard to justify solar when my TOU rates allow me to power my house, Leaf, and PiP for about $80-$90 per month. It's hard to truly calculate the ROI on solar with the unpredictability of utility company rates, and deal with getting permission from a pain in the @$$ HOA (California law might stop them from preventing me to do it, but they'll definitely make the process much more annoying than necessary). Perhaps someday I'll get solar, but probably not before replacing my windows with double pane and replacing my 30+ year old AC unit.
    EDIT: After nearly 3 years with the Prius Plug-in I've done about 55k miles at 57mpg plus another 9k miles on electricity. Not bad for one of those people that bought the PiP solely for HOV access who can't plug in at or near work.
    #17 PriusC_Commuter, Oct 6, 2016
  18. mmmodem
    2,732
    1,703
    Bay Area, CA
    It's interesting you have a Leaf and still find ROI from solar isn't worth it.. I always thought it was a no brainer but with so many variables, I haven't looked into it myself. I do know I won't be getting solar until there is a BEV in the garage.
  19. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    The Leaf is EPA rated for 30 kWh/ 100 miles, so for 50 miles it costs about $1.95 (summer) $2.10 (winter) compared with one gallon of gas in the Prius on my current nighttime TOU rates. Compared with gas prices when I bought the car, that was good enough for me. Again, I only ever charge during the cheap nighttime rates, and only run the AC during those hours too, hence my daytime usage is low and my overall utility bill is generally $80-90.
    In the past 2 years or so, I've seen Southern California Edison do two things to screw over solar owners. First, they shifted their on peak hours back by 2 hours. It used to start at noon, now it starts at 2pm. That's 2 hours of prime solar generation than you now get paid for off-peak generation rates instead of on-peak. Second, they adjusted their rates so that super off peak costs more and on-peak costs less. I'll admit since I don't have solar I don't know the exact specifics, but I'd assume this means they pay less for generation during the on-peak hours. The combination of these two could significantly increase a previous estimate of ROI years, yet there is literally nothing to be done about it.
    I'm sure solar can be cost effective for some, but I just don't see the benefit yet for my specific circumstance (at least until I upgrade my windows and AC, then I'll get quotes). Hopefully by the time I'm ready to do it the costs will have dropped significantly too.
    mmmodem likes this.
  20. mmmodem
    2,732
    1,703
    Bay Area, CA
    PG&E is no picnic up in NorCal. I had EV TOU rates right after I got the PiP but last year they decided to do all of us a "favor" and get rid of tiers. Naturally, without tiers, non-peak rates tripled or something like that... rates are always in flux, I can't keep track. In effect, my usage now costs more to be on EV rates than to be on non TOU tiered rate. Thank you, PG&E. I was happily charging at night off peak but now I charge during the daytime to spite them (and for spontaneous use after work).
