2006 Prius VSC, ABS, (!) lights all on!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shaiden, Sep 20, 2016.
  1. shaiden
    shaiden New Member
    encinitas
    Hey everyone so my 2006 prius suddenly had all these lights turning on the other day. At first the master triangle red light turned on as well but turned off now. Also my tire pressure light is on due to what we think is a bad sensor but its been on for awhile and i think it's irrelevant to this current issue. What do I do?
    I've tried testing the 12 V and from what I'm seeing it seems normal so now I'm at a loss as to what else to do.
    Car is running fine.
  2. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    First thing to do is get the trouble codes read.
  3. bisco
    51,484
    welcome! what is normal?
  4. shaiden
    shaiden New Member
    encinitas
    there arent any fault codes when i use my scan tool
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    515
    Outside Philly, PA
    You need to use a mini VCI cable to read some Toyota specific codes.
  6. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    the red triangle turned on then went back off----check your oil and see if it's low
  7. Patrick Wong
    18,200
    6,497
    While the Prius is READY, look at the inverter coolant reservoir for fluid turbulence. If you do not see this, the inverter coolant pump has failed.
    Since you see the VSC, ABS and ((!)) warning lights on, the skid control ECU definitely has logged DTC. As previously suggested, use Mini VCI to retrieve those.
  8. shaiden
    shaiden New Member
    encinitas
    alright so a P0A93 code just popped up. Inverter cooling system
  9. fotomoto
    5,632
    3,805
    So. Texas
  10. JC91006
    JC91006 Senior Member
    16,723
    8,546
    Toyota is out of these inverter pumps. You'll need to get it online somewhere
  11. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Did do as Patrick said in Post #7? Verify that you see or don't see turbulence/fluid movement in inverter reservoir? If no turbulence/fluid movement when the car is IG-ON or READY, the inverter pump is dead and needs to be replaced.
    Many posts on how to replace.
  12. shaiden
    shaiden New Member
    encinitas
    Yeah the fluid isnt moving. Wasnt this a recall or are they not doing the recall anymore?
  13. JC91006
    16,723
    8,546
    If you have not done the recall, the repair would be free. However Toyota is out of these pumps, you'll probably get a free rental until the repair is completed
  14. shaiden
    shaiden New Member
    encinitas
    Can i use zerex asian fluid in the inverter? Ordered a pump online and am about to install any tips?
  15. JC91006
    16,723
    8,546
    Yes you can use zerex asian
