Not charging at home - GFI tripped
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pasaman, Sep 23, 2016.
  1. Pasaman
    Pasaman Active Member
    289
    111
    Southern California
    Inspired by the other not charging thread but not wanting to steal the thread.
    My 2013 with 35k miles (mostly ICE miles) has not been charging properly at home. I use the charger that came with the car and plug it into my garage outlet that has a GFI. I will plug it in and 2 hours later notice it says it stopped charging, then I see the GFI is tripped. Based on the charge it looks like it's charging 20-40 minutes then shutting down. Other times it charges a couple minutes only. But I've also had it charging fully on some occasions. It appears very random. The charger is quite beat up. Not sure what the guy before me did to it.
    At work my car charges just fine 100% of the time. Do you think it's the charger? Or my outlet? If it's the charger is this something still under the 100k mile warranty?
  2. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    Should still be under warranty. The dealer replaced mine when it became intermittent. Former owner may have driven over it compromising the cable insulation, or rain may have leaked past the seals on the controller.
  3. bisco
    49,488
    is it a dedicated circuit?
  4. fuzzy1
    10,169
    At work, are you using your own charger, or a facility-supplied charger?
    If the former, I'd first suspect your GFCI is going bad. They do that, DIY replacement is not hard for folks comfortable with basic electricity. If the later, then no clue, it could be either.
    Does the charger have its own built-in GFCI? If so, try plugging it into a non-GFCI outlet. If not, you may be able to plug into a non-GFCI outlet with an portable plug-in GFCI. Not the best long-term solution because Toyota advises against extension cords, but it may help long enough for troubleshooting purposes.
    Pluggo likes this.
  5. Pasaman
    289
    111
    Southern California
    It's not a dedicated circuit and at work I use a charger they provide.
  6. fuzzy1
    10,169
    Is the circuit 15A or 20A? What else is on the circuit that may operate at the same time as car charging?
    Plus, not being a PiP owner, can anyone else answer: Does the charger have its own internal GFCI?
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Check and see if the GFCI is a stabbed type installation. That means the wiring is simply pushed into holes (stabbed) and not locked in by screws. I've gone/burned through two of these types in our kitchen that needs to pass a lot of current to other receptacles further along the wall that power a microwave and toaster.
    priuskitty likes this.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yes
  9. bisco
    49,488
    but it can still plug into another gfci, i have not had a problem.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    agreed
  11. Pasaman
    289
    111
    Southern California
    I have no clue if it's 15 or 20a. I'm not that knowledgeable about this stuff. It's a circuit for my garage. The garage door opener and a light is on it but the opener is never going while I charge.
    fuzzy1 likes this.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have used a "kill a watt" meter and found that the charger draws about 12 amps max
  13. fuzzy1
    10,169
    The electrical panel should have labels for the circuit breakers. The 15A or 20A rating will be stamped or embossed in the breaker handle for the Garage circuit. But the light doesn't really matter much, if the garage door opener doesn't run at the same time as the charger, then it doesn't matter what the circuit rating is. The circuit rating would matter if additional devices were plugged in and running.
    That means the charger is safe for a 15A circuit, as long as it is not being shared with anything significant. Any measure higher than 12 amps, up to 16 amps, requires a 20A circuit.
    Pasaman and priuskitty like this.
  14. Pasaman
    289
    111
    Southern California
    I'm not sure if it means anything or speaks to the wiring in my garage but when the gfi is tripped the light on the same circuit won't turn in until I reset it. This may be normal but I have no clue. Just thought I'd mention it.
    It sounds like I'm going to have a hard time telling if it's the outlet/circuit or the charger. Guess I have to find somewhere else to test my charger maybe.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Get a Kill A Watt meter from amazon $18.56
  16. Mendel Leisk
    38,726
    That says to me it's your outlet.
  17. bisco
    49,488
    use the charge finder website to find free 120v outlets in your area where you can plug in to test your evse.
    Pasaman likes this.
  18. fuzzy1
    10,169
    That simply tells us that the light is on the circuit branch protected by the GFCI. It is highly unlikely that the light itself is significant.
    Because he isn't using the same charger at work, I don't believe it helps separate the outlet from the charger.
    While very useful in general, I don't see how it relates to this particular problem.
    #18 fuzzy1, Sep 23, 2016
    Pasaman, Mendel Leisk and priuskitty like this.
  19. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Have you tried a different circuit in your house? If the cable doesn't reach you can use a 12 gauge extension cord, but don't use the cheap 16 gauge orange ones since you want thicker wiring.
  20. Pasaman
    289
    111
    Southern California
    I think this is what I need to try next. I'll try stretching the cord across my front lawn and sidewalk tonight.
