Dealer won't repair problem
Discussion in 'Gen 3 Prius Main Forum' started by dame3780, Sep 23, 2016.
  1. dame3780
    dame3780 Member
    59
    53
    SoCal
    I've written about this noise concern in a previous post. Most early gen 3 Prius' are making this clicking noise when turning, right while braking, under 30mph. I have had this issue for 30k miles. It is not subtle and happens every day under those conditions. Most say the axle is the fix. I bring it to a Toyota dealer, they were unable to duplicate the concern. So I end up going on a drive with a tech later. He confirms the clicking multiple times. Now a week later I get a call from the advisor saying that the tech could not diagnose it and he started blaming my driving style for the noise. It was too late to speak with anyone else at this time of day, so now I'm waiting until tomorrow. I have ext. warranty as well. Who should I speak with first? Service Mgr? Then from there if I don't get any help? Toyota? If anyone has any similar issues and had luck getting it taken care of, please shoot me a message or reply to this thread. I just want this fixed.
    Thanks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Only utilizing one dealer? If so, why not try another dealer if you are not satisfied. Which dealer are you using?
    kc5dlo and Mendel Leisk like this.
  3. Mendel Leisk
    40,919
    I don't know about "most", never heard this. Build date Aug 09.
    Yeah get a second opinion, hope it gets sorted.
    kc5dlo and Raytheeagle like this.
  4. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    +1 with a build date of July 2009
  5. dame3780
    dame3780 Member
    59
    53
    SoCal
    This is the 2nd dealer actually. Not convenient to switch again-closest dealer is 2 hours away.
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    And the second dealer is saying the same as the first? I also thought there would be more than 2 dealers within a 2 hour drive in Los Angeles.
    If you have a written report from the tech that went for a ride with you, you could use that and call Toyota. Usually Toyota wants good documentation.
    How many miles on your Prius? You say this had been happening for the last 30 k miles. What have you done other than trips to the 2 dealers? Greased the slide pins? What is the pad thickness? Any debris or loose pieces like hub caps? Had any work done to the wheels or brakes 30 k miles ago or since?
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    There are a couple of threads covering this issue. It's covered under the powertrain warranty. 5 years 60k miles. If they say it's normal wear and tear CV Joint, then show them the same braking and turn but shift to neutral while doing it. The clicking noise will go away. If it's bad cv joint, it'll click even in neutral. Call Toyota and tell them the dealer refuse to fix the issue even under the extended warranty.
  8. dame3780
    dame3780 Member
    59
    53
    SoCal
    Thanks for the helpful reply. I did mention to the advisor and tech the issue and it does not happen in neutral. I let them know about this site and how many other owners had the same issue and it was the axle that fixed it. I was told he could not diagnose it-basically could not figure it out. This is not ok. Now I'm gonna have to fight to get them to move forward. I'm tired of these dealers.
  9. Mendel Leisk
    40,919
    I too am thinking CV joint going bad.
  10. dame3780
    dame3780 Member
    59
    53
    SoCal
    I believe so too. I guess the service mgr will be getting a call today. I just don't understand how the tech on the road test that heard my concern is unable to diagnose it.
