PIP EV range falloff
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by gallde, Aug 19, 2016.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Without knowing starting point (initial SOC) of each charge it is hard to make a judgement.
    51,895
    now 6 days since the dealer was supposed to call me.
  3. PRPrius
    PRPrius Active Member
    327
    198
    I must be one of the lucky ones, at 121,000 miles I am still getting 12.1 to 12.5 miles per charge. I have to say the display in my car adapts to my driving style. If I am driving in an spirited manner while on EV mode it will lower the estimated range per charge if I have been using the charge faster than normal. There are times when I use up the charge within 9-10 miles when I am stuck in traffic and finally get to the point where the highway opens up. Although we don't get that much traffic on southbound I-35 through north Fort Worth (LOL)!! On weeks when I am having good luck with traffic or it is summer so we have half the number of cars on the road I get my full EV range out a charge. Sometimes I can get up to a mile and a half more than my normal 12.1 to 12.5 miles of EV range. All in all, I am very happy with the consistent range I have gotten since the car was delivered in March of 2012.
    drash, bisco and inferno like this.
  4. inferno
    inferno Senior Member
    1,072
    405
    Was there a kwh charge falloff at all?
  5. bisco
    51,895
    more proof that my battery is defective. 7 days since the dealer was supposed to call. yes, i'm keeping count.
  6. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    Have you reminded them? As bad as service is with overtightening oil filters, they may be even worse with keeping customers informed.
  7. bisco
    51,895
    i don't have a contact. toyota was supposed to have them call me.
  8. markabele
    5,084
    1,782
    Nebraska
    What is your total EV%?
  9. PRPrius
    327
    198
    I am afraid I do not keep track on how many KW it uses when I recharge the battery. I just go strickly by EV range and Trip B on the trip computer.
    I can't recall of the top of my head but I now it is no more than 30%. The Prius is our default road trip car so it has been on a lot of road trips all over the US and Canada. This has resulted in a lower EV% than you average Prius PHV. I should add that we do 98% of the recharge cycles using the car's Level I EVSE. Once in a blue moon do we use a Level II charging station.
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Well if you want to eliminate whether your PiP is in the middle of rebalancing your cells over and over again you could try the following:
    Drive your PiP for a week without any charge. This may allow the electronics and battery to coalesce at the same voltage level. It'll eliminate whether you are going through a rebalancing storm or your electronics (PDU, ECU, etc.) are at fault (or just plain lying to you).
    Unsupervised!
  11. bisco
    51,895
    thanks, how many miles would i have to do? i have been driving 100+ miles, twice a week since june first on hv only.
  12. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    For me it wouldn't be a whole heck of alot. Sounds like from your schedule, whatever you drive in a typical week, ~300 miles or so. You should also track your mileage the trip computer gives you. If its going down that'll be more ammunition.
    Unsupervised!
  13. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    That happens to be what I did, unintentionally. Drove a week without charging. Seems my range went up to like 10.5, hvac off, so about a gain of 1 mile I guess.
    iPhone ?
  14. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Try using just 5 minute recharges too after empty. It'll only add about 2 miles but again it'll allow the the battery modules to coalesce at a given voltage.
    Unsupervised!
  15. bisco
    51,895
    a gain of one mile on the battery icon range estimator, or in real performance?
  16. bisco
    51,895
    wouldn't you think toyota would be smart enough to tell people to do this, so they don't get complaints?
  17. bisco
    51,895
    11 days since toyota was supposed to contact me, i think i might have fallen through the cracks.
  18. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Battery icon range estimator. I don't have the attention span to watch the trip odometer and the battery gauge at the same time whilst driving lol
    iPhone ?
  19. bisco
    51,895
    that's what i was afraid of.:unsure:
  20. bisco
    51,895
    36 days, and i'm down to 13.4 miles.
