I got the 5000 mile maintenance on my C today.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by priusmatty, Sep 27, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    I also had them change oil and filter, since I drive for Uber and I put some wear and tear on the old girl. I had my tires a bit overinflated, and on their report, they said the pressure was 35. Did they actually let air out of the tires, or do mechanics just fill in the numbers that are supposed to be there anyway? lol
    Bigboi likes this.
  2. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    Only way to know is to measure the tire pressure yourself.... that will tell you if they adjusted it or not
  3. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Mine were 40psi on purpose. They def deflated them after i left the lot and checked with a digital tire gauge. Surprised they changed the oil though, dealer told me to change it at 10,000 miles
  4. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    I requested and paid for the oil change, since I drive Uber, and I put lots of wear and tear on it. Probably unnecessary, but I am obsessive lol.
    Bigboi likes this.
  5. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    If you don't mind, how much was it to change oil? I won't know for another year since we still have that 2 year free service thingy for oil changes and maintenances
  6. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    It was $35 or something like that, full synthetic (As Prius requires) including filter (Toyota filter).
    Bigboi likes this.
  7. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I keep my tires 3psi above the recommended pressure and check then monthly. If I don't remember to tell them not to touch the tire pressures when I take my car in for servicing it comes back with the tires at recommended pressure and I have to pump them back up again.
    Bigboi likes this.
  8. Mendel Leisk
    41,824
    Or check them at the dealership before driving off, ask them to top them off. I've found they'll do it willingly, they're not air pressure Nazis, say like Costco.
    And after a few times, maybe they start to see a pattern, realize it's a lot less labour, just leaving them alone.
    I'm keeping ours barely higher than spec, and the same value all around, just for convenience. They're low profile 17" though, with 15" I do raise them significantly moderately over spec.
  9. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    As for tires, doesn't the Two Eco over-inflate on purpose? I am probably going to buy a 2017 Two Eco, so that is cool.
  10. Mendel Leisk
    41,824
    You can set tire pressure on any level where you want.
