Toyota C-HR (Coupe High Rider). Reviews start P. 23
Discussion in 'Toyota Hybrids and EVs' started by Navigare, Oct 5, 2015.
  1. unicorn
    unicorn Member
    48
    EU
    Prius consumption is different in West and Central Europe (probably different ground clearance).
    West Europe - 3.0l (15" tires), 3.3l (17")
    Central Europe - 3.3l (15" tires), 3.6l (17")
    C-HR real consumption can be calculated as follows:
    Prius real consumption (Spritmonitor, Germany) = 4.2l
    Prius paper consumption (17", Germany) = 3.3l
    C-HR paper consumption (17"/18" tires) = 3.8l / 3.9l
    C-HR real consumption (18") = (3.9/3.3)*4.2 = 5.0 l
    Anyway, the consumption dispersion of C-HR will be higher (comparing to Prius).
    E.g., C-HR urban consumption (3.5l, 18" tires) is very close to Prius (3.3l, 17" tires),
    i.e., lower speeds (50-80km/h) will ensure really low consumption similar to Prius.
    Only problem are highways 130km/h :)
  2. Tideland Prius
    16,631
    Not here. RAV4 and Corolla don't have full range DRCC AFAIK. (I think we did confirm the R4h with an owner here)
  3. Sam_Fisher
    Sam_Fisher New Member
    Washington DC
    2011 Nissan LEAF
    anyone from france able to make it to the paris auto show?
    this car cant get here soon enough
  4. Navigare
    Navigare Active Member
    312
    138
    Netherlands
    I just got a call from Toyota Nederland. They invited me to testdrive the C-HR next weekend (8 oct). Very excited.!!!
    Tideland Prius likes this.
  5. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    there is no difference in vehicles sold, they are all the same... some distributors quote lower spec models to give impression of lower consumption. We have CO2 for each model since taxes are based on it.
    I dont think highways will be as much of a problem, unless compared to Prius directly. If we remember correctly, new Prius is very good even at higher speeds, and even when compared to 2.0 TDI. Now C-HR will have much worse aero, but so will Tiguan and other competitors.
    make sure you tell us all about it :)
    #425 spwolf, Sep 30, 2016
  6. spwolf
    3,156
    440
    Eastern Europe
    you are right... Rav4 also works only on speeds over 25mph here in Europe.
    Also notice how they are defining LDA "with steering control" vs "assistance" before. Might be more improved system too.
    #426 spwolf, Sep 30, 2016
  7. Navigare
    312
    138
    Netherlands
    What do you think? :)
    Sure thing.
  8. unicorn
    unicorn Member
    48
    EU
    ... just interesting information from Toyota Central Europe (CZ/SK/HU) -> "Prius for Central Europe has higher ground clearance, consequently, slightly higher consumption" (+0.3 l)
  9. unicorn
    unicorn Member
    48
    EU
    C-HR boot space LxWxH ?
    Thanks. :rolleyes:
    (Note: two versions with/without JBL, European method up to the rear seat back)
    Edited (Jan 2017): link to answer http://tinyurl.com/gmqydl4 (HonestJohn.co.uk)
    #429 unicorn, Oct 7, 2016
  10. Navigare
    312
    138
    Netherlands
    Unfortunately i was ill on saturday, so couldnt drive the C-HR. :(
    Others that were driving had the Nissan Quashqai, The Rav4 Hybrid and the 1.2 T and Hybrid versions of the C-HR to compare.
    Hybrid C-HR came out on top, 1.2 T second (nice power), and Nissan and RAV4 last.
    #430 Navigare, Oct 9, 2016
  11. spwolf
    3,156
    440
    Eastern Europe
    so what did the people say when commenting them?
  12. Navigare
    312
    138
    Netherlands
    Very nice driving abilities, nice position behind the wheel, bad rearview vision. Great looks.
    spwolf likes this.
  13. spwolf
    3,156
    440
    Eastern Europe
    What about interior?
  14. Navigare
    312
    138
    Netherlands
  15. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Pricing of the hybrid all over Europe is very very competitive. Prices of C-HR in different countries in EU is different, but price premium against 1.2t MT is almost in all countries only 3,000 €. That is price premium that will even out after 100,000 km at European gas prices, not to mention depreciation.
    The only sense to go for 1.2t is because of 4x4 option and higher tow rating.
    Is this price premium for real or does Toyota just take less profit margin on a hybrid, 1.2t engine may be more expensive than 1.8 in hybrid, but probably not by much. I don't see it as they are selling this things with low profit, because even Toyota estimates they will sell 70% of C-HR as hybrids:
    We started taking orders this month and are very confident this new entry in the growing cross-over segment will further help grow our sales into 2017. From what we can see so far, nearly 70% of customers will choose the hybrid version.”
    http://newsroom.toyota.eu/pressrelease/5299//toyota-motor-europe-sales-electrified-hybrids?searchresult
  16. Trollbait
    12,738
    A 1.2L engine will use less metal than a 1.8L one. Then I'm guessing the turbo is a small one, and not something for high performance, so it won't add much to the cost. So the 1.2t is cheaper or about the same as the 1.8L. Then the 1.2t is likely using the same transmissions as is behind other engine options, or one that shares a lot of parts with them.
    The hybrid transaxle should be cheaper than a typical transmission, but there are the add on parts; two MGs, inverter, battery, etc.
  17. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Thanks for explanation that doesn't explain anything :D
    Two MG, Inverter, battery, electric accessories ... all for 3.000 EUR minus taxes, I don't buy it.
    Things that are in 1.2t:
    - High pressure fuel pump
    - Single scroll turbo charger with intercooler
    - Direct injectors
    - VVT-iW, Variable Valve Timing-intelligent Wide (don't know if this more expensive than VVT-i )
    - Cylinder head that uses an integrated water-cooled exhaust manifold
    - 6 speed manual transmission and clutch
    Thing that are in 1.8:
    - Amount of metal is negligible considering price, but OK
    - Cooled EGR (maybe this is also in 1.2t but didn't find anything about it)
    - Exhaust heat recirculation system
    My guess is profit margin on 1.2t is like 15% and profit margin on hybrid is 5%, prove me wrong. :p
  18. Trollbait
    12,738
    Get me Toyota's books then.
    Toyota can be taking less profit on the hybrid, but they also waited for a third and fourth generation hybrid system before expanding the lineup of models outside Japan.
    Considering that they still use old 4 speed automatic transmissions in new cars, Toyota is going to squeeze as much profit as they can out of all their products.
  19. spwolf
    3,156
    440
    Eastern Europe
    Doesnt seem like premium is that much anymore... Toyota is most profitable manufacturer in the world and they sell 1.5m hybrids per year... so if they were not profitable, they would drag on their profit.
    edit: I actually checked pricing of Auris 1.2t vs Auris Hybrid in small eastern european countries where they dont push hybrids and difference is 5k for Auris, 3k for C-HR... so pricing different has certainly improved, 4th gen hybrid is not only the best technology wise, it is also significantly cheaper for them.
    #439 spwolf, Oct 12, 2016
  20. Sam_Fisher
    Washington DC
    2011 Nissan LEAF
    no new news?
