suspension
Discussion in 'Gen 2 Prius Technical Discussion' started by billh, Sep 30, 2016.
  1. billh
    billh Junior Member
    27
    cleveland
    Had my 06 in for new struts and rear springs (one broken). Mechanic told me there is a thin pencil like structure underneath the car that point down and that is broken. does anyone know what this is? I have the top package, don't recall if that is 8 or 6, but has leather/touring etc.
  2. PriusInParadise
    180
    91
    Hawaii
    You don't say what area of the undercarriage you found the broken part (front, back, left, right, center...).
    If your 06 has HID headlights, there is a suspension height sensor that has a link connected to the left rear suspension. The height sensor is used for the headlight leveling system.
  3. bisco
    48,965
  4. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    A cell phone picture would be helpful!
  5. Patrick Wong
    18,199
    6,464
    That probably is one of the two links that attach the front sway bar to the strut housings.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The Touring debuted in 2007. Top of the line for 2006 was Package 8.
  7. billh
    billh Junior Member
    27
    cleveland
    It was probably this height sensor. Pretty sure it was in the back area of the undercarriage, but the mechanic didn't point it out to me.
  8. billh
    billh Junior Member
    27
    cleveland
    as I recall (10.5 years ago) dealer salesman called it touring. You suggest that "touring" is different than VSC.
  9. JimN
    7,028
    1,116
    South Jersey
    The Touring Packages had 16" wheels, a larger spoiler, and a different suspension. Vehicle Stability Control was included in Package 4 and higher. In later years it eventually became standard.
