Prius Prime Questions
Discussion in 'Prime Main Forum (2017-2022)' started by ArtVanDelay23, Oct 4, 2016.
  1. ArtVanDelay23
    ArtVanDelay23 Member
    61
    62
    ny
    • Can the white plastic on the steering wheel be replaced?
    • Can the white plastic on the shifter be replaced?
    • What is the preorder process?
    • When will the Prime hit dealers in California?
    • When can consumers in California anticipate test drive opportunities?
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    No, but you may be able to cover it.
    No, but you may be able to replace it.
    Don't know.
    Don't know.
    Don't know.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    late Nov to dealers was previously mentioned
    Sept 30 first date of manufacture was previously mentioned
    for everything else, there's MasterCard
  4. bisco
    51,895
    i thought they already did the rolling test drives.
  5. estebinbin
    estebinbin Member
    184
    47
    If you really don't like the white plastic areas one can always inexpensively vinyl wrap those areas. It is not as hard as one might think, all one needs is a steady hand when cutting out the openings.
    alexgrigori and Trollbait like this.
  6. Trollbait
    12,520
    This a common mod for covering the interior portion of the Chevy bowtie. I've done it after a rock cracked that area, and it is a simple process.
  7. DavidA
    2,344
    1,820
    Chicago western burbs
    So, if you don't mind me piling some questions of my own into this thread, here they are.
    For the Prime Advanced:
    1) Regarding the automatic on/off headlights… Can I easily override this automatic settings by manually turning the headlights on and off? If so, can I do that from the stalk? (hopefully there isn't fiddling with a menu) We've got a mandatory headlights on law in Illinois in daytime when it is raining. It can be bright enough in a rainstorm that auto headlights wouldn't turn on by themselves.
    2) The rain sensing wipers look interesting. Can I override that also? Is there a sort of intermittent switch in the Advanced in addition to the auto setting?
  8. Tideland Prius
    16,554
    1. Yes. There are the 3 regular positions plus AUTO.
    2. You can disable rain-sensing and have it as a regular intermittent wiper.
    DavidA likes this.
  9. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    I dislike the rain sensing wipers on my Ram. The irregular wiping cycle is distracting and annoying to me. I prefer a regular predictable wipe. Also I use rainx-x so it wipes automatically much more than I need it to, and there is no adjustment for it.
  10. Prius Maximus
    955
    810
    Northeastern IL
    Questions - reverse camera. On the prime, can it be viewed on demand or only while in reverse? Are there indicator lines on the screen? If so, do they move with the steering or are they static?
  11. MitchR
    MitchR Junior Member
    42
    Nashville, TN
    Can the front passenger seat fold forward? I often carry long items like boards and want to know how much length I would have.
  12. Lee Jay
    5,850
    4,036
    It can fold backward, almost to flat with the back seat (might be able to get it there with a little elbow grease). I've carried things 10 feet long before onto the dash, but 8 foot boards onto the front seat when folded back are no real problem.
    MitchR likes this.
  13. MitchR
    42
    Nashville, TN
    Thanks so much!
  14. Lee Jay
    5,850
    4,036
    This is in a gen2, but the gen4 isn't too different.
    10 foot pipes: 10D_3276.JPG
    8 foot boards: 20D14649.JPG
    bisco and MitchR like this.
  15. MitchR
    42
    Nashville, TN
    I saw a video showing the interior of the prime when it is started and turned off. There was an annoying chime and graphic thing going on. I can't find the video. It was about 30 seconds long. Has anyone seen it?
  16. DavidA
    2,344
    1,820
    Thank you, Tideland. Good to know.
  17. bisco
    51,895
    yes, all prius chime. that's their m.o.:p
  18. Lee Jay
    5,850
    4,036
    My 2004 doesn't.
  19. bisco
    51,895
    someone probably shut it off.
  20. Prius Maximus
    955
    810
    Northeastern IL
    I shut mine off. Job #1 on getting home with it the first time. (Job#2 is rain-xing the windows.)
