What's this little black box?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Max Camacho, Oct 8, 2016.
  1. Max Camacho
    Max Camacho Junior Member
    Irvine, CA
    Does anyone know what this little black box is? I want to see if i can tap the wires to install a dashcam and a radar detector but I need to know what it's wired up to and see if it can handle the load. I can't find it on TIS, but I'm sure once I find the name of it I should be fine.
  2. JennieB
    JennieB New Member
    Kansas
    I think it's the windshield wiper sensor. (I could be wrong.)
  3. ChapmanF
    18,959
    If you're signed into TIS, you ought to be able to find it in the Electrical Wiring Diagram viewer, if you start in the location and routing section. You'll see little drawings of the cabin, with letter-numbered callouts pointing to things in different positions. If you click the right callout and hit the Info icon, you can be taken straight to the circuit that includes it, and find out what it's there for.
    One trick with those location drawings is they might be split into several pages, just because of the number of things needing to be called out. Each page shows the same drawing and all the same items, but only some of them are called out on each page; you just keep switching pages until you find a callout pointing to the thing you're wondering about.
    -Chap
  4. Mendel Leisk
    42,271
    I'm pretty sure there's a thread here, someone wired up a dash cam getting power from those wires in the rear view mirror. Likely 3rd gen, but I'd suspect it's similar. I looked a bit, got couldn't find it, so fwiw.
  5. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    max,
    I believe it houses the lane departure warning, where camera/sensor sees lane makings, and gives you a beep and pulls steering a little towards the opposite direction you car is drifting to.
    I have a 4 with this feature. Not sure if your car has this.
    It even beeps/pulls steering back if I change lanes without signaling.
    Read you manual if yours has this feature.
    Be aware that touch electrical things, may cause other problems, and void
    your warrantee.
    stt
  6. Jorge L
    Jorge L Junior Member
    Mexico City
    That's the rain sensor.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    There is no rain sensor on his Two model. I asked that same question a few months ago. My Three has the box.
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    sensor for the blinker fluid level?
    you never want to run out of blinker fluid.
    RCO and Coast Cruiser like this.
  9. Coast Cruiser
    2,267
    2,571
  10. Coast Cruiser
    2,267
    2,571
    I think somebody told me that black box up there by the mirror, has something to do with the climate control/humidity.
    I don't have the Advanced Tech Package, or rain sensors, etc. Maybe it's just an empty box?
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Just a shot in the dark, but could it be the camera for pedestrian detection?????
  12. sttkailua
    190
    151
    Hawaii
    For cars so equipped.
    stt
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thanks stt
  14. Coast Cruiser
    2,267
    2,571
    The OP has a Two model,which I believe doesn't have any advanced tech features.
    RCO likes this.
  15. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    You could disconnect it and see what happens.
    grape808 and Coast Cruiser like this.
  16. Coast Cruiser
    2,267
    2,571
    Great idea, Oddjob. :D
    Mine in a skinny box, about 4 inches long? People with the ATP have a bigger/wider box up there, I think.
    As long as I keep getting 64 mpg, I don't care what it is!! :ROFLMAO: (But it might be nice to have a factory-installed dash cam up there. Toyota should offer it.)
  17. Max Camacho
    Irvine, CA
    Oh, sorry. I forgot to mention that it's a Prius 2 eco. I was thinking it could also be the GPS tracking device, since I have an app for that as well and it seems to be the perfect place for it.
  18. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Your photo shows 2 wires coming out - was there a cover over the wires - it doesn't look like a factory installed item.
  19. ChapmanF
    18,959
    You know, Toyota does tend to stamp a part number nnnnn-nnnnn on pretty much every odd little electronic part. If you dismount the little thing and look closely you may well find the number, which you can then often google.
    -Chap
    RCO likes this.
  20. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    It's a humidity sensor used by A/C unit.
    MDNHW11 and pakitt like this.
